seat belt conversion and install
You could go with the F-Body rear belts. That's what I did on my 71'.
Gary
http://forums.corvetteforum.com/c3-t...through-2.html
Gary
Gary
Gary
THANKS
The stock-type conversion is expensive. I am not aware of a "kit" so you have to order parts piece-by-piece. Here are the guides, bezels, and moldings with pass-through slot. Obviously the top of the seat has to come apart.
The belt/retractor is available from a company called Andover in Maryland.
Before you do anything you must verify that the steel/threaded reinforcement plate was installed in the wheelwell fiberglass by the factory. That is a rubber plug in the threaded hole (passenger side).
This is the Bubba method of pirecing the carpet in the right location for the retractor mounting bolt (driver's side)
I had to cut holes in the moldings/covers.
It was a tedious job but I am pleased with the results. The F-body option is probably an easier job.
Paul 74: Thanks for the post -- that's where I'm going. Two (2) questions.
1. In the parts needed photo, the two red parts, where do they go and what direction do they go in? I suspect they go behind the seat.
2. The little bracket that the quarter trim panel screws into below the re-inforcement threaded hole. Any chance you can post a photo of it, with carpet pulled back? I just checked my vert and I don't have them. But I plan on installing them some how!!! So a photo would be helpful.
TI
Looks great!
TI
Looks great!
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
TI, in 69 the belts are mounted on side of the fender, not on the top as Paul's pics show. That plug in your pic should be for the shoulder harness retractor. If you go with the late model F-body rear seat belts, they MUST be mounted on top of the fender to work properly. Here is the bracket I made for my 69 to mount the belt on the top of the fender.
Paul 74: You didn't mis-lead me! I have a 1974 and "GREATLY" benefited from your post. I'm sure others enjoyed it as well with the excellent photos. With out a doubt your post is pertinent as it shows how to do it and the parts that are needed -- a viable alternative.
Answer the two questions if you can, or feel free to send answers by email Zip960@***.net I have new belts which I will be installing soon.
I also picked up some knowledge about 1969 Vettes. c69vete did some beautiful work fabricating a bracket!
It is all about Teamwork and learning from each other. I'm indebted to all of you.
one of the really great things about the way c69vete did his install is that the retractor will not interfere with the opening of the rear compartment doors. i have the original belts on my 69 convertible and when you open the compartment doors they hit the retractors and will not stay open without holding them. also there would be less of a tendency for the belt to twist and jam the retractor when the belts retract. maybe check the junkyard for the retractors. i know i have seen them on some cars.
Paul 74, what is that you have on the floor on the passenger side, looks like a protection for the carpet?. Thanks to all for the posts, now I am prepared to install one additional harness.
St. Jude Donor '07
Paul 74. I apoligize if I offended you. That was not my intention. You do beautiful work and are one of the people here that I go out of my way to read what you post. I was trying to point out some of the subtle differences of the 68/69 verses the later C-3's. This seemed relevent to what TI wanted to accomplish.
TI
Looks great!
TI
Looks great!
My carpet is now more firmly fastened down and I prefer not to pull it up. Sorry....
They come in black. I used plastic paint to approximate my oxblood interior.
St. Jude Donor '07
Sorry but I do not have any pictures like you want on my computer. I do have a couple of more of the bracket though. I can take a pic this weekend when I get home from vacation.
The quarter trim panels are 70-75. The 69 are shapped differently and are made for the retractors mounted on the side of the wheel well. These are a better fit for the late Camaro seat belts.
St. Jude Donor '07
Here are the brackets I made for my 69 seats.
Here are the seats I have now in my 69. Fiero seats with the seatbelt pass-thru.
http://s42.photobucket.com/albums/e3...100_0544-1.jpg
