View Poll Results: 383 or 350?
350
5
11.63%
383
38
88.37%
Voters: 43. You may not vote on this poll
need help on engine choice!
Old Aug 4, 2010 | 07:19 PM
Vettekid1992's Avatar
Vettekid1992
BUILD AN LS1!!!!!!!!!!!! the motor will give u the power u want easy. the conversion is so simple!!!!!!
Old Aug 4, 2010 | 07:45 PM
rx3191's Avatar
rx3191
i had thought of that back when i first got the car, i have an ls2 with a rod knock sitting at home too, that may be a good prodject for later...
Old Aug 4, 2010 | 07:59 PM
billla's Avatar
billla
St. Jude Donor '14
Originally Posted by Ben Lurkin
+2 for the 406 SBC. I've never understood the 383 attraction at all. 450 hp will me more easily obtained with the x-tra cubes. You could even use the factory nodular iron crank at that level and still be ok.
The attraction is kind of a holdover from when the 400 had an undeserved bad reputation. I think folks also get overly focused on keeping their existing 350 block.
Definitely true that it's HP/CID that costs money..the lower the ratio, the better the $/HP.
It is getting harder to find decent 400 blocks, although the aftermarket has filled in nicely with some very high quality products at a price that makes looking for a used block for any serious power goals kind of a waste of time.
