1982 R134 fitting problem
Old Aug 4, 2010 | 06:10 PM
Ivan_the_Red's Avatar
Ivan_the_Red
Default 1982 R134 fitting problem
I am going through the retrofit process to R134 from R12. All was going well until I got to the part where you assemble the new fittings onto an available port for the high and low pressure taps. I located the low pressure tap on the back of the compressor without any issues but when I attempted to assemble the high pressure fitting onto the small aluminum line that runs under the fender, the fitting did not tighten down correctly. I dis assembled it and noticed that the fitting port has a flat end on it (on the aluminum line) unlike the low pressure that has an s.a.e. fitting on it. Is this correct or am I trying to locate thge high pressure adapter to the wrong location. I looked into the fitting supplied with the kit and it also has a flat seat area with a flat o-ring..... seems like a pretty ****ty design if it is in fact correct. Has anybody out there experienced this issue before? How did you solve it?
Old Aug 4, 2010 | 06:59 PM
rx3191's Avatar
rx3191
i have run into this before one my different cars, there is 2 different sizes for high side r12 fittings, the small one is the most common (same thread as low side) but there is a large thread also(i don't know the size) you local parts store should have the fitting you need if not i know napa sells them, if i can find a part# before i leave work i will post it for you
Old Aug 4, 2010 | 07:11 PM
Ivan_the_Red
Thanks for the reply, the fitting I have is a 90 degree swivel type and it had a flat o-ring in it. I was able to tighten it but not enough to keep it from rotating by hand. It almost seems like the port I am trying to put this fitting on was not designed to have an adapter put on it since its end is flat not tapered. I dont think it would contain 220 p.s.i. Do you know of another high pressure tap that I could use instead of the aluminum line under the fender?
Old Aug 4, 2010 | 07:17 PM
rx3191's Avatar
rx3191
there isn't anyother spot on the high side that i know of, i can look at my vette when i get home and tell you for sure though, i hate the 90 degree fittings i have had bad luck with sealing, the o-ring is normal it seals on the top of the old fitting right before the treads
Old Aug 4, 2010 | 07:21 PM
Ivan_the_Red
did you end up using a straight fitting without an issue?
Old Aug 4, 2010 | 07:41 PM
rx3191's Avatar
rx3191
i did use the staight fitting on mine with out a problem, i have an 81 it's a little hard to get the fitting on but i just very littley bent the line to make it alittle easiyer be very carful if you tweek the line though they are very soft and bend easy
Old Aug 4, 2010 | 08:37 PM
Ivan_the_Red
did you put the fitting on the aluminum line coming from the condenser going to the evaperator? where did you get that fitting from ....do you remember?
Old Aug 4, 2010 | 11:13 PM
81pilot's Avatar
81pilot
If you are trying to fit it on the back of the compressor it is the wrong spot. That is a pressure releif valve. Look along the fender right in front of the heater box you will find them neither of which are a part of the AC line or Compressor, they come off of the condenser on an aluminum line. They will go on easily. Find the right ports and you will see it is a simple application. The 81 and 82 share AC construction and I just did mine.
Old Aug 4, 2010 | 11:42 PM
rx3191's Avatar
rx3191
81 is correct, i just went out and looked at my car, the line is right above the coolant bottle running along the fender, the low side (blue r134a fitting) should go on the larger line along the side of the evap case. i will get a pic for you hear in a few min...
Old Aug 4, 2010 | 11:55 PM
rx3191's Avatar
rx3191
this is where the fitting should go, this is how they are set up on my car
Old Aug 5, 2010 | 06:29 PM
Ivan_the_Red
Thanks for everyones help, I went out to Autozone last night and bought a straight fitting that was designed a little differently and all is well as far as I can see (its under vacuum right now). Interesting post earlier regarding the use of the port behind the compressor for a low pressure tap. I have read in many other posts that there are many people that use that location to charge at rather than the port above the low pressure switch. What do you think......is that port safe to use or not?
Old Aug 5, 2010 | 07:10 PM
noonie's Avatar
noonie
Perfectly fine to use the one at the compressor as long as you only use the refigerant vapor (can upright) and not the liquid (can inverted)
Old Aug 5, 2010 | 08:55 PM
81pilot's Avatar
81pilot
I wouldn't it does not give the liquid enough time to pressurize into a vapor and can over pressure real quick on fill up. It might be OK, but not where it is meant to go in.
Old Aug 5, 2010 | 09:32 PM
rx3191's Avatar
rx3191
when i charge from there i use the machine at work and it forces the freon in without the compressor running, charge slow and with the can upright and you should be ok
To 1982 R134 fitting problem
