clocking spark plugs?
Old Aug 4, 2010 | 10:25 PM
jboweriii's Avatar
jboweriii
Default clocking spark plugs?
How much difference do you think it makes with nitrous. Some guys at the track are doing it. These are cars running 5's in the 1/8
Old Aug 4, 2010 | 10:38 PM
Roughrider's Avatar
Roughrider
For a street car it means nothing. For a car running such low times at the track...every little thing you can do is a help...even if it's just a feel good thing.
The performance gains might be technically measurable, but in the real world of street driving, it's likely no more than a mirage. Keep your entire ignition system in top condition and something like clocking your spark plugs is unnecessary.
For a car with nitrous, I'd be more concerned about making sure the engine doesn't blow up from overdoing it.
Old Aug 5, 2010 | 05:26 AM
PowdercoatBill's Avatar
PowdercoatBill
I've been running Nitrous on my cars for years and never indexed the plugs. I think it's more important for the guys runnin' big kits, or multipable stages. For a street car fuel pressure and ignition is all you'll need to be worried about.
Old Aug 5, 2010 | 08:12 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
The interesting part when you dig into it is that there are several versions of what *optimum* indexing of the plugs should be. Some have big domes on pistons and need to keep from hitting ground straps. Some don't have any fire slots in domes and want to get fire over the dome, some want to keep plug cool with fuel wash, some want to aim it to hottest part of chamber, some want it up, some want it down...........
The only way to know what your motor might like is to do a lot of testing. Might help a hair....might mean nothing.
JIM
Old Aug 5, 2010 | 09:10 AM
Timsride's Avatar
Timsride
Clocking was originally done because domes were hitting ground tabs. I wouldn't waste too much time on this unless You think its not firing right on some cylinders. Its a lot of work for nothing. Also be carefull what You use to mark the plugs with because that could be the easiest ground for Your spark, and You could weaken spark to cylinder. Just My 2 cents.
To clocking spark plugs?
