Now What, steering box pics
Old Aug 5, 2010 | 07:46 PM
z10kl's Avatar
z10kl
Default Now What, steering box pics
When swapping control valves and finding out my pitman arm hole was enlarged, I changed the pitman arm and now I find this play in the pitman shaft. I dont know if it was there before but it moves up and down about 1/4 inch. What could cause it and could it have been there before I messed with it?
When I push up on it.
Old Aug 5, 2010 | 08:00 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I think the center alignment bolt of the steering box is missing or broken, you have to stop driving your car till you fix it.
Old Aug 5, 2010 | 09:37 PM
z10kl's Avatar
z10kl
So is this what happens when you remove the pitman arm by hitting the puller stud with a hammer to break it loose? What should I do? I haven't looked at the top of the box yet.
Old Aug 5, 2010 | 09:39 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
There must be a lot of play where the lash adjusting screw is attached to the pitman shaft.
Or the cover has has stripped threads for the screw.
Old Aug 6, 2010 | 04:25 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
again : DO NOT DRIVE YOUR CAR, this is a seriously damaged steering system.
Old Aug 6, 2010 | 08:10 AM
z10kl's Avatar
z10kl
I lowered the car and looked at the top. The aluminum cover is broke.
Old Aug 6, 2010 | 11:49 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by z10kl
...What should I do?...
Replace the steering box and the pitman arm. Put the hammer away in a safe place.
Old Aug 6, 2010 | 06:19 PM
Tom Sarno's Avatar
Tom Sarno
I have an extra box. PM if interested
Old Aug 8, 2010 | 08:53 AM
aussiejohn's Avatar
aussiejohn
Default Sorry to hear that.
z10kl,
You need a new box. I suggest that you look up www.borgeson.com, they have rebuilt standard boxes or a new integral power steering box that will transform the driving sensation of your car.
The Borgeson boxes come with a factory three year warranty.
Regards from Down Under
aussiejohn
To Now What, steering box pics
