82- Will not start with Spark Control Connected
Old Aug 5, 2010 | 09:22 PM
EWJ's Avatar
EWJ
Default 82- Will not start with Spark Control Connected
I am working on getting this 82 running right.
I've replaced the fuel pump- the car now runs. When I first got it running, the brown Spark Control wire was already disconnected. Now that it was running, the initial timing was set to 10 degrees advanced. The distributor was tighened down, the timing again verified as 10 degrees.
I then connected the brown wire and attempted to run the car again: it wants to start, but will not.
With the wire disconnected, it runs- with the timing at 10 degrees.
What to now check? Should I replace the control unit in the distributor? Or...?
TIA
Old Aug 7, 2010 | 04:26 AM
jeffp1167's Avatar
jeffp1167
TIA
should be a est module somewhere
Old Aug 7, 2010 | 08:22 PM
Wrecked82's Avatar
Wrecked82
Whar is an EST module?
Old Aug 9, 2010 | 12:08 PM
jeffp1167's Avatar
jeffp1167
I will try and find it on my 82 and take a picture.
Old Aug 9, 2010 | 06:31 PM
hugie82's Avatar
hugie82
There is an oil pressure switch in the system you may want too check also. I'm not sure if it kills the fuel or the spark?
To 82- Will not start with Spark Control Connected
