Power Antenna Question
Old Mar 26, 2002 | 12:33 PM
Andrew's Avatar
Andrew
Default Power Antenna Question
How do I take out the power antenna? Is this hard to replace? Is there a trick to this???
Old Mar 26, 2002 | 12:45 PM
American Boy's Avatar
American Boy
Default Re: Power Antenna Question (Andrew)
I took mine out this winter and it was nearly a breeze. From the top, there is a nut that you have to remove, a special tool is require to do this. If you don't have it, a punch with a hammer and a lot of caution will do the trick. After that, there is a bolt from underneat to take off and the antena to disconnect. There is a connector from the interior of the car to get or you can cut the wire and solder them afterward. If you want to rebuilt your power antena here a link http://www.corvettemagazine.com/2002...tenna/ant1.asp
I know it's for C4 but the first generation for them is the same as for late C3.
Stephan
[Modified by American Boy, 11:46 AM 3/26/2002]
Old Mar 26, 2002 | 12:53 PM
RATT7's Avatar
RATT7
Getting acces to the power Antenna should not be to hard - I did find it a tough squeeze due to the muffler being in the way some what - but its not to bad all. When my Antenna went years ago I replaced the whole unit from GM - I have noticed that the vendors now have a replacement mast which you can buy for under $20. Most Antenna problems is due to the cable mast braking - Ex you turn the radio on and you here the Antenna grinding but the mast is either stuck in the down or up position. I f your Antenna is doing the same thing then just replace the mast . hope this helps
Old Mar 26, 2002 | 03:14 PM
gkull's Avatar
gkull
Default Re: Power Antenna Question (RATT7)
Make sure that it's not a power problem first. I went through the PITA of replacing mine and it wasn't the problem. It seems to me that I got on the bottom nut with a small vice grips.
[Modified by gkull, 1:16 PM 3/26/2002]
To Power Antenna Question
