Tranny or Engine oil cooler?
Old Aug 6, 2010 | 08:42 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Tranny or Engine oil cooler?
Which is more important to have in a 95% street driven car....transmission or engine oil cooler?
Old Aug 6, 2010 | 10:35 AM
Roughrider's Avatar
Roughrider
Transmission cooler is more important. Essentially only cars that race and tow heavy loads require the use of an oil cooler, but automatic transmissions require one all the time.
Some older cars with automatics didn't come with transmissions coolers but engines didn't run so hot then as now plus transmissions weren't as sophisticated then as well. I have an SUV with factory tow package and it came with an oil cooler, but that was intended for more than just street driving.
Adding an engine oil cooler isn't a bad thing to do...just not required for street driving. Regular oil changes are more important. If you want to add an oil cooler go for it.
Old Aug 6, 2010 | 10:50 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
The only time you need an auxiliary engine oil cooler is if you're typically seeing oil temps nearing ~240*F or above. FWIW, thermostatic control valves are available.
Old Aug 6, 2010 | 12:40 PM
Hvymtlc5's Avatar
Hvymtlc5
Makes sense. I had both mounted but never hooked up when I was turning the car into a Friday night only thing. Now that the wife wants to drive it more I'm taking most the stuff off that isn't really need or performance related.
Old Aug 6, 2010 | 01:29 PM
jordan89's Avatar
jordan89
Tranny oil cooler. Especially if you have a high stall converter. I have a cooler on my auto '78 Z28.
Old Aug 6, 2010 | 04:28 PM
gerry72's Avatar
gerry72
Indeed. You can not run an auto trans too cool -not talking harsh arctic temps here- and the cooler you can run it, the longer it will last. Engine oil needs to reach at least 212 degrees just to boil out the water from condensation. Unless the engine sees sustained high rpm (like running a steep gear for a long highway trip), it's not likely the engine oil will get close to the danger zone of 260 and up.
Old Aug 6, 2010 | 06:02 PM
cargo247's Avatar
cargo247
Tranny oil cooler
Todd
Old Aug 7, 2010 | 07:13 AM
jb78L-82's Avatar
jb78L-82
You definitely cannot run a tranny too cool under most conditions as noted above. I have been running tranny coolers external to the radiator (I do not run the lines into the radiator with tranny coolers-the tranny coolers do all the cooling) since 1978 rear round in various other cars I have owned. 1973 Nova SS auto with (2) tube and fin coolers-168,000 miles when sold. Currently, 2001 Pontiac Grand Prix with the crap 4T65E FWD transmission-(2) 18,000 GVW double stack Long coolers-101,000 miles on the tranny and a 1994 Mustang GT auto with one 28,000 GVW double stack Long cooler. Never had a tranny failure yet.
As for the oil, agreed that an oil cooler is not necessary on the street. However, this idea that the oil has to get to 212 degrees to burn off water vapor, I have not witnessed in 31 years of owning cars. Again, Nova SS had on oil temp gauge that I installed and the oil typically ran about 175 degrees. The 78 corvette has an 81/82 oil temp gauge where the analog clock used to be (I installed that back in the 80's) typically runs also 175-180 degrees and my 2010 Z06 oil temp gauge typically runs 175-180 degrees and has NOT gone over 200 degrees yet! Just an FYI.
Old Aug 7, 2010 | 09:30 AM
TimAT's Avatar
TimAT
I had a chart from GM at one time that listed various temps and trans life expectancy based on those temps. I'm still looking for it. I know it's somewhere.
To Tranny or Engine oil cooler?
