L83 carborated
Old Aug 11, 2010 | 12:15 PM
76 camaro car's Avatar
76 camaro car
Default L83 carborated
I have a 82 corvette engine I am going to put in my 76 camaro. I plan on removing the dual crossfire setup and will switch to a 4bbl carborator. I am also running headers into a dual exhaust. Has anyone done this conversion and about how much horsepower increase should I expect ? Also has anyone heard anything about putting 305 heads on a 350 block and the pros and cons about that. The car I am building will not be the main car I will drive but I still would like to be able to drive it around town. Also what is the best cam to run with this setup? Thanks
Old Aug 11, 2010 | 02:05 PM
markdtn's Avatar
markdtn
You can use an 82 long block with a carburetor, just change the intake and add a fuel pump. You can use 305 heads on a 350 physically, but you would have about 12:1 compression and severely shrouded valves-don't do it.
