Head, and Head Bolt Installation Problem
I am in the process of installing my rebuilt heads on my 75, L48. Here is where I am at:
Picked up new.038 composite gaskets (to allow for any variance in the heads or block).
Cleaned block surface with razor blade and vacuum.
Cleaned block threads. I used a tap (not a thread chaser, I know, I know, this may not be the best). Now I was VERY careful, went in only about 3/8 inch and never saw any metallic reminants on the tap, only left over sealant from the original installation. Then I ran a bolt into each hole to clean up any remaining old sealant.
Reused the head bolts, cleaned by the engine shop, sealed with Permatex 2, oiled the bolt heads with 30 weight oil.
During the installation, only 1 bolt turned into taffy. While doing the final torque (20, 40 and then 65 ft lbs) on the #5 bolt, I felt the bolt start to give way. I stopped and proceeded to the remaining bolts. All the other bolts on both heads went in with no problem and no sense at all of weakness or stretchyness.
I bought a set of Fel-Pro head bolts, replaced the #5 bolt and the new one went in great, felt super and that was that.
I was so impressed with the presealed bolts from felpro, I though, hey, why not replace all the old bolts.
So, I pulled out the #1 bolt from the other head. Put in the new bolt and then at about 65lbs, the bolt started to stretch. UG! How could a new bolt stretch! So, I put back in the old bolt and it tightened right up, with no problem at all. Surprising
That's when I went back to the auto shop, a local regional parts store with its own machine shop. They have been around for a long time; we are not talking autozone here. The guy there, who used to work in the machine shop was very surprised and said it must be the block. He suggests pulling everything off and reinstalling with all new bolts.
I called the engine shop that did my heads, (not the same shop at the part's store, but a reputable, race engine building shop), and he said that as long as all of your bolts are properly torqued, you are OK. In otherwords, although he can't explain why the new bolt twisted, if the old bolt is in there at the right torque spec, don't worry about it.
I borrowed another torque wrench from autozone to get a second opinion on my torque wrench (mine is a 15 year old Craftsman with the internal clicker, not a dial, and not a digital). The OTC wrench clicked out at about 70 foot pounds, so it is possible that my craftsman wrench is off by 5 lbs and the head bolts are installed at 70 ft lbs instead of 65. according to the manual, though, this should be ok.
So who to believe and what should I do?
1. Redo everything with new bolts - as per the parts store? (note, the parts guy felt so strongly in his opinion he said I could have the parts for a very good discount, so his motivation is not to just sell me more stuff)
2. Leave it - as per the racing engine shop, "everything is torqued properly, should be ok"?
FYI, here's a picture of the first bolt that stretched.
Spend a couple bucks for the ARP bolts and feel confident.
A potential problem down the road will cost you more than the bolts.
The cheaper clicker wrenches screw up sometimes too.
If price is any indicator, I see that ARP are better bolts. The FelPro bolts were only $23 for one set. Even thought they are made in the US, I too agree that the FelPro bolt failed and not the block.
I'm still on the fence as to what to do; I'll continue to research and seek out opinions.
Thanks!
Jamie
They are softer than the bolt threads. When the new bolts torque to the proper spec. they had better and stronger threads. They bit better than the threads form the factory bolt.
I'd run a bolt into the hole in question and see how much lateral and vertical play there was. If that hole has more than the rest of the holes, I'd put in a Helicoil and not have any doubt.
If you don't know for sure, there will always be that doubt in the back of your mind. Doing it correctly is much better than guessing that it may be going to hold.
I've learned that, that maybe it will, or maybe it won't concern isn't worth it when you are in position to make the correction at little cost. I'm wondering why the machine shop didn't offer that suggestion?
IMHO
My 2centavos
If a sleazeball wants to make money #1 he will find an cheap and easy way. #2 if the same guy is doing this he could give a crap and half if your $7,000 motor went up in smoke.
You wont see any serious drag or road course driver using anything but ARP bolts and studs and on a serious piece and with that in mind I wouldn't use ARP hadware on anything but an Premier Padmini or Hindustan Ambassador India Taxi.
Hopefully the bolt failure didn't cause any permanent damage to the head bolt hole
IMO this is very good advice from a professional. If I were going to go with anything other than OEM I would (and do) use ARP hardware. For an L48 (very docile, low compression engine) I would not have bought the set of head bolts, I would have asked the machine shop if they had a good OEM bolt laying around to replace the one that failed. I fully expect they would have given you one. Bottom line is if you do decide to change them, use ARP, I would think we all agree on that.
If those hole threads are damaged to the point of giving up torque, they may fail you down the road (no pun).
I know other builders who have employees who impact wrench the core motors apart. Often doing the thread damage. I've let them go myself for the same reason. One of the reason I chase all threads before assembly, is to get a feel for the quality of the hole threads.
A helicoil restores the bite you are looking for, and being a steel thread will last as long as the engine.
IMO
IMO
Bob's auto-shop sells the blue thread repair kit it. I might work or I'll bet $100 it doesn't.
You need to find out what is wrong, it's either the thread's f'uped in the hole or bad 25cent head bolt.
Like the old commercial used to say " You's can pay me know or you can pay me later"
If it runs in hard the edges of the hole threads may be pulled up a bit.
Putting one together and hope it works is when Murphy gets his foot in the door.
Thank you for providing your comments and ideas.
I spent the day regreasing/rebuilding the steering gear. Good news there is that with only 35k miles, the tolerances in the gear were within spec and the old grease looked good. At least something went well.
