Flywheel question???
Old Mar 27, 2002 | 06:58 AM
Steve Adkins's Avatar
Steve Adkins
Default Flywheel question???
Should the starter ring on the flywheel be greased a little before installed? I know you shouldn't grease alot due to the fact that it might sling on the clutches, but it seems like a little won't hurt.
Old Mar 27, 2002 | 09:20 AM
vettfixr's Avatar
vettfixr
Default Re: Flywheel question??? (Steve Adkins)
No, you should not grease the flywheel ring gear, there is no need. It will fling grease in the bell housing if you do and clutch dust will collect on it. Remember the flywheel spins as fast as the engine and anything on it will quickly be thrown off.You should put a little grease on the starter gear so that it slides easily.
Old Mar 27, 2002 | 01:08 PM
Steve Adkins
Default Re: Flywheel question??? (vettfixr)
Thanks, that makes sense. :yesnod:
To Flywheel question???
