Correct speedo drive gear
Old Mar 27, 2002 | 09:41 AM
467-Ratman's Avatar
467-Ratman
Default Correct speedo drive gear
I need to change my speedo drive gear in my muncie. Its a green gear now and my speedo reads fast about 10%. Which gear do I need, one with fewer teeth or more. I have a 3:70 rear gear with a M-20 trans. Thanks!
Old Mar 27, 2002 | 10:10 AM
Gordonm's Avatar
Gordonm
Default Re: Correct speedo drive gear (467-Ratman)
I have a gray gear with 22 teeth in mine. I have a M20 with 3.70 gears.
Old Mar 27, 2002 | 10:19 AM
467-Ratman's Avatar
467-Ratman
Default Re: Correct speedo drive gear (Gordonm)
Thanks Gordon, Sounds like I need more teeth on the gear. I found the gears in Corvette Central for $8.50. Do you know if I could get it from a local Chevy dealer? Or someplace else. Thanks
Old Mar 27, 2002 | 12:00 PM
vettesite's Avatar
vettesite
Try some local trans shops. I swapped my stock gear for a new one when I changed my ring and pinion set.
Old Mar 27, 2002 | 12:16 PM
Gordonm's Avatar
Gordonm
Default Re: Correct speedo drive gear (vettesite)
I think I got mine from Corvette Central or Zip. I was ordering some other stuff so I just put it in with the order. Local trans shops or dealer might be worth a try.
Old Mar 27, 2002 | 01:03 PM
jerryp58's Avatar
jerryp58
I got a drive gear from my local Chevy dealer (in stock).
If I remember correctly (not always the case :crazy: ), the ZIP catalog said 1-1/2 MPH for every tooth.
To Correct speedo drive gear
