heater control lamp
Old Aug 15, 2010 | 04:01 PM
79c3man's Avatar
79c3man
Default heater control lamp
I was rebuilding my heater control ,yesterday ,it had broke lens and plate, I noticed there was no lamp .there are cut wires for a lamp and with a test light work with the headlights ,what does the socket look like and where does it go ,I would like to see the controls at night thanks 79 vette
Old Aug 15, 2010 | 04:59 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The lamp for the heater control is in the upper part of the center dash bezel.
The only wires in the dash that I can think of for a lamp would be one for the cig lighter...
I'll see if I can get you a pic.
Willcox
Old Aug 15, 2010 | 05:30 PM
0Willcox Corvette
Former Vendor
Best pic I had..
Old Aug 15, 2010 | 09:06 PM
speedreed8's Avatar
speedreed8
those could be the wires for the gear selector indicator lamp. if its an automatic.
http://www.corvetteforum.net/c3/tune.../index23.shtml
Old Aug 15, 2010 | 10:00 PM
79c3man's Avatar
79c3man
this lamp in the top of the dash bezel ,does it twist out to remove ,I see the screws ,do I need to remove them thanks again
Old Aug 15, 2010 | 10:24 PM
speedreed8's Avatar
speedreed8
yes it twist out to remove, the bulb is in a socket holder that just twist out, i've changed my bulb before by removing the glovebox inside , and reaching through. no need to remove the screws.
the pic from willcox upper pic is the socket holder base, that is mounted with the screws. lower pic is of the aimer lens, directs the light to the controls.
Old Aug 16, 2010 | 11:19 AM
VetteProject's Avatar
VetteProject
I just bought both parts from Willcox, how does the aimer lens install/mount?
To heater control lamp
