I have had a couple of flat batteries in the past 3 weeks.
While out driving today I noticed that the inside light on roof and by my feet were still on, when I got home I sat in the driveway with the ignition off and keys out but still the lights did not go out.
As I do not always get a flat battery, this is an intermitent problem.
Were should I start looking ?
Three things keep the interior lights on. A bad door switch, the HL switch turned all the way to the left, or the time delay. Sure you havent turned that HL switch on?
Check that your door switches are properly adjusted,they can come out of correct setting to turn lights off when door is closed after a timed delay with convenience group option or right away without option. I have had this problem once,adusting door switches fixed it for me.
Then the timer is likely bad. Behind the glove box. You can remove it entirely and tie the two white wires together.
I did this years ago when I had the same problem. Interior lights will come on when door open and off when closed. Just no longer a delay. Works perfectly.
