4" Sidepipe baffle / insert recommendations
Old Aug 16, 2010 | 01:23 AM
sokoloka's Avatar
sokoloka
Default 4" Sidepipe baffle / insert recommendations
As I've posted nine million times here in the past few days, I recently purchased a '72 that came with sidepipes similar to the Hooker style many of you purchase for your own vehicles.
After doing a little research, I found out that they are the eBay brand "OBX" hooker style sidepipes, and from what I can see there's little to no difference between them; although I'd love to get some black hooker's and headers in the near future.
My question now is: They're completely open as of right now. While it sounds great, it's also deafening at times and I'm sure my neighbors aren't the biggest fans either.
What recommendations do you guys have for baffles or inserts? From reading, I know there's a member on here who makes their own, as well as the hooker brand sleeves and Sweet Thunder as well. Any others?
Does anyone know if there's any fitment issues with the OBX pipes? I assume these inserts just slip in behind the headers?
I do plan on getting the black hookers sometime soon - will I be able to swap the inserts over as well later on?
Thanks for all your recommendations!
Old Aug 16, 2010 | 09:18 AM
Corey_68's Avatar
Corey_68
STS Baffles is the way to go IMO, and do forget to pick up a Set of Dean's Shields
http://www.spiralturbobaffles.com/corvette.html
http://www.steelshields.com/
Old Aug 16, 2010 | 11:16 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I've had Hooker sidemounts for the better part of my life, and after having given a bit of thought to Hooker MaxFlows I'll most likely be going with 2.5" Sweet Thunders behind my 427 redux. The 'glass packs (had them also) apparently aren't nearly as free flowing as they sound. Everyone's got their own particular taste, but to my ear STS's sound a bit tinny. Don't care for reverse flows at all (too quiet/restrictive). Suggest you don't even think about open pipes on the street.
Coat the joint at the collector, as well as all fasteners, with anti-seize so it won't be such a pain to remove for changing inserts.
Have no idea what OBX pipes are. Inferior Chinese knockoff??
Old Aug 16, 2010 | 11:48 AM
sokoloka's Avatar
sokoloka
eBay brand of exhaust components from what I understand.
Don't look half bad actually - but definitely not my choice to put on the car. Will look into getting the sweet thunder inserts! Anyone have any experience with the 2.5" vs the new 2.75" ones they're offering?
2.5" still sound decent?
Old Aug 16, 2010 | 02:54 PM
TheSkunkWorks
You can listen to sound files here..
http://www.sweet-thunder.com/
The reasons I'm probably going with 2.5" vs. 2.75" are for a little more attenuation as well because that was the collector venturi diameter once recommended by Chevy Power for racing BB's with 4" pipes. No real science behind that choice, yet. However, if I can afford to purchase and test both sizes when I get to dyno day with my fresh mill (also have a set of Hooker sidemounts just for that purpose), I'll do so and post up results, but don't hold your breath in the mean time.
Old Aug 16, 2010 | 04:23 PM
eastltd's Avatar
eastltd
FWIW, I have the 2.5" Sweat Thunders and found them on the loud side. I contacted Mike at Sweat Thunder and he sent me a set of 2" to 2.5" adapters that mount in the inlets and they did knock a few dB's off the sound.
If I were to buy another set, I would try the 2" to see if they are more street friendly.
Old Aug 16, 2010 | 05:32 PM
'75's Avatar
'75
I have the 2 1/2 sweet thunder inserts as well and they are a little loud for my taste. I e-mailed them about a way to quiet them down a bit but got no response. Is there a part number for that adapter?
Old Aug 16, 2010 | 06:06 PM
Duke94's Avatar
Duke94
That's what I have. Also, if you do a Forum search, you'll find lots of threads on this subject. I think there was even a couple that had sound bites attached so you could hear the difference.
Gary
Old Aug 16, 2010 | 06:40 PM
TheSkunkWorks
Thanks for that feedback. Hate to give up HP over a few dB, especially when the HP I'm after doesn't come cheap, but know I'll have to weigh the one vs. the other, at least for street use.
Old Aug 16, 2010 | 07:19 PM
68-427Rich's Avatar
68-427Rich
Default Baffels
I've used the STS for years. I have a set of low mileage Hooker straight through mufflers I would sell cheap. My 427 wouldn't rev past 4800 with them.
Old Aug 16, 2010 | 09:41 PM
ddn's Avatar
ddn
STS baffles are the real deal. They sound great, do not hinder performance, and quite possibly increase it.
Old Aug 16, 2010 | 10:47 PM
glackore's Avatar
glackore
Default Recommend STS
I just bought a new set of Hookers. My old set got thin and I ended up blowing a hole in the #6 tube. My new set is from Jet-Hot, black cermaic coated. I took my STS mufflers out of my old pipes and installed them in my new tubes. I love the sound - goes with the performance aspects of my hot rod.
Old Aug 16, 2010 | 11:31 PM
eastltd's Avatar
eastltd
There was no part number and he didn't charge me. Call him, I'm sure he'll help you.
If not, the part is a simple 2" diameter exhaust pipe, 4" long, swaged to 2.5" at one end.
Sorry, I didn't take a picture.
Old Aug 17, 2010 | 12:32 AM
stavanger's Avatar
stavanger
Here is mine.
2-1/2" Sweet Thunder chambered inserts in Hooker Side
http://www.youtube.com/watch?v=mpRPqs6R3-o
Old Aug 17, 2010 | 02:31 PM
auavette's Avatar
auavette
STS baffles are awesome, been using them uncapped. Sounds great.
Old Aug 17, 2010 | 05:58 PM
redman76's Avatar
redman76
St. Jude Donor '09
I like the STS too. Sound good, perform well. The best part to me is that they are somewhat tunable by drilling out the center cap. You can run capped, with different sized holes, to completely uncapped; gives you different sound and performance levels. If they get too loud, you can always recap them.
Old Aug 17, 2010 | 07:00 PM
'75's Avatar
'75
Mike from Sweet Thunder e-mailed me today, looks like he is going to send me a set of those adapters.
Old Aug 17, 2010 | 07:20 PM
eastltd's Avatar
eastltd
I knew he would come through.
Let us know if you hear a difference
To 4" Sidepipe baffle / insert recommendations
