Advice on headers please.
Old Mar 27, 2002 | 01:27 PM
OO72LT1's Avatar
OO72LT1
Default Advice on headers please.
I'm keeping the exhaust manifolds with the original LT-1 motor and would like get headers for the ZZ4 i'm installing. Any thoughts? I noticed the spark plugs on the ZZ4 are angled, could this be a problem with the header I get? Also, how do I swage the end of the pipe?
Thanks.
Old Mar 27, 2002 | 01:37 PM
stroked 76's Avatar
stroked 76
Default Re: Advice on headers please. (OO72LT1)
my advice would be a set of full length HOOKER headers for your vette.they seem to fit the best in a vette and arent that expensive.you will need to repipe the exhaust to the mufflers.have the headers acid cleaned if you can when you get them and then paint them with a good header paint they will look good.they are cheaper priced headers availble for vette but i have found hooker fits the best 1 5/8 size good luck
Old Mar 27, 2002 | 02:01 PM
Green76's Avatar
Green76
OO72LT1,
I would recomend Hooker Super Compteition 1 3/4" headers with ceramic coating, that's what I'm using and they bolt right on without any problem, the only plug that is hard to get to is #8 plug plenty of clearence for the spark plug boot. The ZZ4 has larger exhaust ports than the stock cylinder heads have, that's where the 1 3/4" pipes helps out no restrictions...
Hooker headers come with a 3 bolt flange welded on all you need is a couple of reducers to match up to your pipes you are going to use.
Black68Vette's Avatar
Black68Vette
Do sidepipes!
Old Mar 27, 2002 | 02:23 PM
kgraumann's Avatar
kgraumann
I also used the Hooker Super Compteition 1 3/4" on my ZZ4. They worked the best for my application. I have a manual trans and they worked without flaw. I did make the mistake and did not buy the ceramic coated, and later had Airborne Coatings do the ceramic/black coating. I would have been cheaper to buy it already coated. Ceramic cuts down on the heat inside the engine compartment.
Old Mar 27, 2002 | 02:26 PM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: Advice on headers please. (kgraumann)
I'm using the Hooker comp headers and they fit like a champ. I had mine cermaic coated locally. They look OK, but not as good as Jet Hot, but not as costly either. Make sure you get some type of coating inside and outside. I have no problems with the headers melting my plug wires.
Old Mar 27, 2002 | 03:16 PM
OO72LT1's Avatar
OO72LT1
Default Re: Advice on headers please. (Paul 75 L82)
What's should I expect to pay for the Super Comps with coating? Anyone ever heard of Alumicoat?
Old Mar 27, 2002 | 03:34 PM
Ken74Conv's Avatar
Ken74Conv
I too, am putting in a ZZ4.
Has anybody used Hedman headers?
I heard their headers mate well with the "D" shaped ports on the ZZ4.
Old Mar 27, 2002 | 04:13 PM
kgraumann's Avatar
kgraumann
Default Re: Advice on headers please. (Ken74Conv)
I tried hedman headers, but would not work with the steering damper on my model. I was told by hedman tech support they don't support headers on corvettes that use steering dampers. So I sent them back and got my money back. But that has been a year back, so they might have changed these by now.
Old Mar 27, 2002 | 04:32 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
I still undecided on the headers or the 2 1/2 '84 SS tube Corvette manifolds I have.
I called Summitt and they want $299.95 + $179 for ceramic coating for the SUPER COMP.
The Competion std. header with ceramic coating is $320.95 or $141.95 without.
Question? Is the upgrade to the SUPER COMP's worth it? ....................I just know you're gonna tell me yes, right? JIM
Old Mar 27, 2002 | 04:34 PM
Ken74Conv's Avatar
Ken74Conv
I'm not sure what you mean by a "steering damper"
Is this on a 1980 and maybe not on a 1974?
Old Mar 27, 2002 | 04:37 PM
Black68Vette
The dampers generally got used on manual steering cars, not power steering (yay, mine is manual, and there isn't on it it, thanks bubba!)
kgraumann's Avatar
kgraumann
This confused me also, as I always thought that 78-82 had the steering dampers. But Hedman told me they did not always come with steering dampers.
It looks like a sideways shock absorber on your steering linkage, it is sideways between your front tires.
Old Mar 27, 2002 | 04:50 PM
Ken74Conv's Avatar
Ken74Conv
I didn't know that was a damper. I thought it was a hydraulic cylinder.
It has lines in the end of it. I am about to replace mine because it is leaking. You think thats the piece Hedman can not accommodate?
Old Mar 27, 2002 | 05:10 PM
kgraumann's Avatar
kgraumann
Yes, that is what I was told by Hedman. I argued for sometime with their tech support, as I thought all corvettes 78-82 had them.
So I just bought Hooker, I paid a lot more for them, but in the long run came out better. They bolted up effortless.
Old Mar 27, 2002 | 05:19 PM
robzr's Avatar
robzr
Default Re: Advice on headers please. (PROSOUTH)
Well if your choice is between Dynomax 1 5/8" Jet Hot coated headers for $219 and Hooker Super Ceramic Coated for $470, then it depends on your horsepower level and driving style. AFAIK it sounds like 425-450 hp is about the crossing point where the benefits of 1 3/4" begin outweight those of the 1 5/8". However it also depends on your driving style as well, if you have a drag oriented car you'd probably want the larger ones, if you have a torquey street car, you can weight the benefits of the 1 5/8". I'm not sure what, if any, the advantages of the 1 5/8" Hooker Comps are over the cheaper, coated 1 5/8" dynomax.
Rob
Ken74Conv's Avatar
Ken74Conv
Thanks for the advice.
By the way, how do you like the ZZ4?
Old Mar 27, 2002 | 05:45 PM
kgraumann's Avatar
kgraumann
ZZ4 is an awesome crate motor and the right horsepower for me. It is a joy to drive now.
To Advice on headers please.
