door problem
Old Aug 18, 2010 | 04:52 PM
cherokee2602's Avatar
cherokee2602
Default door problem
The door on my 1976 L-82 hangs down a bit when I open it. Is there a shim or something to fix this?
Old Aug 18, 2010 | 06:56 PM
Hornevette76's Avatar
Hornevette76
Sounds like the hinge pins need to be replaced
Old Aug 18, 2010 | 07:54 PM
BHRIG's Avatar
BHRIG
The problem is probably the hinge bushings.
To replace them (check to see if the are even there) you will have to remove the hinge pins.
You can accomplish this with the doors on...but make sure to support the door from the bottom.THEY ARE HEAVY.
If you chose to remove the door the hinge bolts are located on top behind an access plate at the front of the inside door..lower hinge is easiest removed behind the kick-panel on the left side of the driver"s foot.
The task is easy........getting to it, a little more complicated..
Good Luck
To door problem
