The water temp should be around 180-210, the oil temp around the same values. Oil pressure depends on the rpm, anywhere from 30-70psi should be fine. What are your values?
Oil temperature should be around 215-220beg.F .. This will assure that any water(condensation) will be boiled out of the oil. If your water temp is between 180 and 210 that should be within normal range. :cool:
Marck
Thanks,looks like everything is fine then.Water is 180,oil too,and oilpressure is ±50. :cheers:
