Quadra-bog?
Old Aug 20, 2010 | 02:42 PM
shake-N-bake's Avatar
shake-N-bake
Default Quadra-bog?
Hey guys, Sorry about another carb question, but I'm a complete newbie when it comes to carbs. I bought my 75' about a month ago now. It runs well, but when I go WOT in second or more more noticebly in 3rd gear, I get good buck and bog when I get up over 3000 rpm I'd say. It seems to me like it's a problem with the secondaries opening up. But in 1st, I can run to redline seemingly fine. A mechanic that I know took a very brief look at it and pointed out a place he thinks should be connected. He said that this vacuum break should be connected to one of these points in the front of the carb? He said to test and see which ones suck vacuum while the engine is running, seemingly both do. Does this make any sense to any of y'all?
Old Aug 20, 2010 | 03:00 PM
baxsom's Avatar
baxsom
The nipple on the distributer is the vacuum advance. It should be hooked up. Read the timing sticky to see the differences in hooking up this item. The nipples on the carb are vacuum nipples. Some have vacuum at idle (use your finger to check) This is manifold vacuum. Others have no vacuum at idle. This is called ported. Depending on wether you want to use ported or manifold vacuum for your distributer (again read timing sticky) run a vacuum line from your selected nipple to the distributer and then plug the others.
Old Aug 20, 2010 | 03:03 PM
Mashman's Avatar
Mashman
Yes - you definately want to get your vacuum advance hooked up.
Your vacuum ports should be either hooked up, or capped.
The first port on the left I believe would be for a choke pull off - your's is on the rear of the carb, so that one I believe should be capped.
The port furtherst to the right, I think, should be the one you want to use for your vacuum advance.
The port in the center, I think you need to move a hose around for. The big hose on the left front, the one with the tee - does the big hose go to the PCV valve, and continue around to your vapor can. And the smaller hose that is teed off of it go straight to the vapor can? If so, the large hose is connected to the correct port, but I believe the smaller one should not be teed off of it - it should be connected to the circled port in the center.
Matt
Old Aug 20, 2010 | 03:06 PM
SIXFOOTER's Avatar
SIXFOOTER
The first pic indicates the vac advance can oon the distributor, for a good running engine you want that connected to manifold vacume, the bottom most nipple on the second pic.
Cap the other 2 and retest, bet ya see better results. Provided that your distributor advance mechanisms work properly.
Old Aug 20, 2010 | 03:30 PM
shake-N-bake
Hey guys thanks a lot for the quick response! However, do we have two conflicting opinions here?
1. Hook the advance up to the rightmost port
2. Hook the advance up to the bottom port (larger port).
Am I reading right?
But hey thanks a bunch for the info already.
Old Aug 20, 2010 | 03:45 PM
Mashman's Avatar
Mashman
Here's a link that might help.
https://www.corvetteforum.com/techti...D=86&TopicID=3
Old Aug 20, 2010 | 03:46 PM
shake-N-bake
Originally Posted by Mashman
Perfect! Thank you
Old Aug 20, 2010 | 04:16 PM
Artsvette73's Avatar
Artsvette73
It would be interesting to know the number of this carb. It's the first I ever saw with a secondary choke pulloff with no primary pulloff on a corvette application
Old Aug 20, 2010 | 04:48 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
I have a carb virtually identical to that except with a straight fuel filter boss...
The manifold vacuum is sourced from the nipple at the upper right (passenger side) of the carb above the fuel filter boss. The lower left nipple is ported vacuum; the mid-level left nipple is for EGR timing. It acts like ported vacuum, but is even slower to apply vacuum.
Next time you have the carb apart, take a look at where these passages go. BTW, the above reference is for a 4MC or 4MV carb; yours is an M4MC (post '74) and is considerably different and has different vacuum hookups.
Old Aug 20, 2010 | 05:40 PM
shake-N-bake
Alright, so I hooked up the distributor advance to the upper right nipple. I went out for a cruise and the first blow seemed to work well: no bog in second or third gear. I ran her up a few more times and did find quite a bit of bog. I got one more clean pass out of it, but not much better if any better than before.
I'd be more than happy to post up the ID number. Where would I find that? I looked around initially but didn't see it.
Yea I found that as well, although the diagram seemed to look the same. Would there be that much difference?
At this point though you guys have answered my question, so I thank you for that.
Old Aug 20, 2010 | 05:48 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Agree with the above; run manifold vacuum to your vacuum advance on the distributor.
But that won't help your problem at WOT (vacuum advance is out of play). It sounds to me like your air valves (upper butterflies on the secondary side) are likely opening too early giving you a bit of a bog.
Do a search on how to adjust (tightened) a bit.
Good luck!
Old Aug 20, 2010 | 07:24 PM
hwcoop's Avatar
hwcoop
Cliff Ruggles book on rebuilding performance Q-Jets is an excellent source of information. should be available at most performance stores or on line @ http://www.cliffshighperformance.com/
Old Aug 20, 2010 | 08:33 PM
Artsvette73
The numbrt will be on the main body. On a vertical plain above the secondary throttle shaf on the drivers side. Should begin with
170XXXXX
Old Aug 21, 2010 | 01:34 AM
rcread's Avatar
rcread
Since this engine is new to you, and you got it with the vacuum advance disconnected, I would suggest a complete tune up including checking the timing, advance curve and valve lash. I wouldn't look at the carb until you have done this.
Old Aug 21, 2010 | 10:36 AM
shake-N-bake
Yup, probably a good Idea.
Old Aug 21, 2010 | 04:43 PM
81pilot's Avatar
81pilot
I know you said you hooked up the distributor vacuum advance, but did you at least cap the others before your test? If not there is no way that thing will run right with those huge vacuum leaks. The large bottom one is for your PCV valve, and it needs a pcv valve, not to run properly but to get proper crankcase ventilation and burn the gases form the crankcase. But in any event cap those and make sure you have no other vacuum lines not hokked up, they are more than likely teed to something and will also cause a vacuum leak.
Old Aug 21, 2010 | 07:25 PM
shake-N-bake
I did cap them off again. They were all capped in the first place. I'll look into getting a PCV valve?
Old Aug 21, 2010 | 07:35 PM
shake-N-bake
170XXXXX
Here it is: 17051194
Old Aug 21, 2010 | 08:15 PM
rcread's Avatar
rcread
That should be a good carb for you if built for your combination. It was originally for a '77-'78 305.
To Quadra-bog?
