HEADS vs. COMP RATIO
Old Aug 24, 2010 | 01:42 PM
billla's Avatar
billla
St. Jude Donor '14
Originally Posted by 99 Black Bird TA
that in mind 100 octane unleaded is fairly easy to find if pricey, if you have any pinging etc and don't want to back off the timing etc.
Where? If you're talking about 100LL Avgas, yeah - you can get it - but be careful as a) you're not paying road tax, b) you're technically trespassing if you go to an airport pump and are not a pilot/mechanic/etc. and c) the additive formulation is different.
Better off to just buy some racing fuel and mix at home. I kept my old '69 350/350 L-46 pretty happy with a splash of Rockett mixed in
Old Aug 24, 2010 | 01:56 PM
pauldana's Avatar
pauldana
Originally Posted by Project80
If the OP sticks with his Edelbrock Performer RPM Manifold and 600 CFM Carb and changes his mind about about switching out the cam, what cam/rollers, heads and gasket thickness would you recommend for him (and others)? I guess this is based on an original stock motor.
cam.... I am running the Edelbrock rolling thunder signature series... it is a little hotter than the rolling thunder cams and the RPM cam. I have been very happy with the cam...(436tq at he rear wheels) currently fighting other valve train issues..... but that brings up another issue... valve train, there is a LOT more to it than just the heads.... SPRINGS LIFTERS, RR'S all play a major part in the RPM and thus HP of the car.... if your valve train is not good, you can have $6000 heads and it will not do what you want.
I would never ever never ever go again with a flat tappet cam with todays oils, and the roller will never go flat an you...
if you are going to spin this motor up to 6+K that 600cfm is not going to be adequate.
gasket thickness can not be noted unless you have all the other specs... which you dont have..but with cast heads dont go above 10.5:1, and aluminum not above 11:1... or you will ping on 92.... I know:-)...... and worrying about finding higher octane gas when out on a run is a pita...
Old Apr 17, 2011 | 07:40 PM
hadams's Avatar
hadams
Default Update
All,
Winter project COMPLETE
Everyone was right…Naturally!
I installed shorty ceramic headers ($65 at Carlisle, and I sent them out for ceramic treatment) (couldn’t properly fit an x-pipe), an Edelbrock RPM Performer Intake Manifold, Edelbrock 600 CFM Carb (both for $200 used) and 1.6:1 Roller Tip Rockers ($90 at an auto swap in CT)
It’s improved in the 3-5K RPM range and a bit snappier on the low end (probably because the Q-Jet needed a rebuild) but not significantly different.
It's all about the heads!!!!!!!!!!!!!!!
It certainly looks decent though after all the cleaning, painting and detailing
Last edited by hadams; Apr 17, 2011 at 07:55 PM. Reason: Update: Take alook at the pictures I posted in my profile
Old Apr 17, 2011 | 08:29 PM
Oldguard 7's Avatar
Oldguard 7
Originally Posted by hadams
All,
Pix,pix,pix, We want pix!!!
Old Apr 17, 2011 | 08:43 PM
hadams's Avatar
hadams
Default How?
OK UNCLE,
I can't figure out how to add pictures to a post
