control arm reinstall problem
Old Aug 22, 2010 | 06:42 PM
mj9311's Avatar
mj9311
Default control arm reinstall problem
i removed the upper and lower control arms to replace the bushings and ball joints. i went to put them back together and i pressed the bottom ball joint on to the bottom of the wheel assembly and when i went to attach the top i now have a 4 - 5'' gap i compressed the springs correctly and i don't think i can compress them much more ... any suggestions?
Old Aug 22, 2010 | 07:08 PM
skids's Avatar
skids
Put a floor jack under the control arm and jack it up.
Old Aug 22, 2010 | 07:15 PM
CFD E59's Avatar
CFD E59
You might have to loosen sway bar link.
Old Aug 22, 2010 | 07:33 PM
mj9311's Avatar
mj9311
sway bar is lose and if i jack it up the whole frame just moves theres no motor in it
Old Aug 22, 2010 | 07:45 PM
76stingracer's Avatar
76stingracer
Get a coupe buddies to stand on the frame in the engine bay so you can compress the spring via jacking the lower a-arm.
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Is the upper bump stop installed? If so remove it. It will let the upper arm drop some. Not sure if it will be enough though. The stop can be reinstalled later.
Old Aug 22, 2010 | 08:27 PM
Indiancreek's Avatar
Indiancreek
Put a chain over the upper arm and around and under the floor jack. As you jack the chain will hold the upper arm as you compress the lower arm up.
Old Aug 22, 2010 | 08:54 PM
micks69's Avatar
micks69
get about a 2 1/2foot section of all thread rod at Home depot or lowes buy two nuts and some fbig washers. remove the shock put the rod through the holes and crank her down
Old Aug 22, 2010 | 09:01 PM
mj9311's Avatar
mj9311
agreed i just went in the garage and pulled out a piece of threaded rod and 2 3''x6'' 5/8 steel plates i think that should do the trick
Old Aug 22, 2010 | 09:17 PM
micks69's Avatar
micks69
i used steel plates too and drilled holes, over simplified it. Works great still have my setup from 5 years ago.
Old Aug 22, 2010 | 09:31 PM
mj9311's Avatar
mj9311
good to hear ill let you know tomorrow when i try it hopefully it works as well for me as it did for you
Old Aug 23, 2010 | 10:58 AM
mysixtynine's Avatar
mysixtynine
Did you tighten the bushing bolts already? Seems like that upper control arm is horizontal to ground (hanging on the bushings).
If so loosen them back up so the control arms just flop around. You aren't supposed to tighten the bushing bolts until the full weight of the car is back on them.
Also I would attach the spindle to the upper arm first so that its weight will pull down on the upper arm.
Most cars that have the motor in them still will be easy to compress the lower control arm up with just a floor jack and not need a spring compressor. You look like you have your old springs still. Unless your springs aren't in the pockets correctly?
Old Aug 23, 2010 | 11:56 AM
wcsinx's Avatar
wcsinx
This
Make sure the spring ends are within about 1/2" of those little holes at the end of each spring pocket. Some guys stick a screwdriver or drill bit through them so they can bump the spring end against it.
The stock springs sit high and have a lot of throw. You will no doubt have to squash them a bit with a jack regardless. I replaced mine with a set of aftermarket F41 type springs that gave me about a 3/4" drop, and I barely had to compress them if at all to get the ball joint nuts started. You might look into them. Your springs look original, and replacements are cheap.
To control arm reinstall problem
