disassembled my short block for a re-ring job, but i cant get the old rings out of the pistons. anybody got any tricks? ive soaked them over night in a bucket of carb cleaner, and I boiled them for half an hour. nothings working.
DAAAAAAMN! I think this picture beat the twisted driveshaft pic in the parts disaster post!
My bet is that the piston top collapsed due to high pressure and squished the ring. I always replace the pistons on a rebuild..........and sell the pistons to the aluminum recycler for $5.........for beer!
block was just honed. motor had been redone before apparently because the machine shop said the bore was already at 4.001 i gave it to them. It cleaned up at 4.003. Im trying to just do a re-ring job. obviously i have to replace this piston, but i dont want to have to buy 8 new ones and have everything rebalanced. I might as well get performance stuff at that point, and i dont have the cash right now.
It probably won't be just one piston that way. I've honestly never seen one that didn't come out pretty easy...which leads me to believe that a) there are other issues and b) I wouldn't expect the rods/crank/etc. to be in very good shape either.
The shop can take the one piston and weigh it, find a piston that's close and then weight-match the piston. I'm assuming when you talk about rebalancing, the assembly is already balanced? I'm not sure what all was done here...
You can get some pretty darn inexpensive "rebuilder" cast pistons...and still be better off than doing a re-ring. But honestly - with around .004 clearance or better (clearance is generally built into the piston) you shouldn't expect this to last very long But we've had that discussion before - so I'll just sincerely wish you good luck
b) I wouldn't expect the rods/crank/etc. to be in very good shape either...
Everything else seems to be fine and in good shape.
stock rotating assembly. balanced at the factory i assume, or when ever it was rebuilt. either way, i wasnt going to change out any parts.
The drag guys run that much clearance or more. Im comfortable with it. yes i know there are differences btwn drag and street motors, but like i said, im comfortable with the clearance.
Back on topic: ANY TRICKS?!?!?!? i dont want to give up easy. help me out here guys.
set them on a hot plate with the rod up......aluminum expands faster than the ductile iron of the rings so maybe you can get the ring gap to open a smidge......enough to get the rings out.
Stock rotating assy's aren't balanced; the setup is within a certain bobweight and called "close enough".
Racers run forged pistons, which are set up with very wide piston/bore clearances as they expand far more...stock, cast pistons are set up with .00075 - .001 clearance. But if you're comfortable...
what is this, the third time i have to ask? I dont want to be a dick, but I didnt ask for a critique of this build. I'll throw up a thread later for you guys to lace into me about all the ish you dont like. ::sigh:: i know, i should be used to this by now. I'M WILLING TO DO THINGS THAT YOU WONT LIKE. now that we're passed that..
anyone have any tricks to get rings off the pistons?
*EDIT: its late, im tired, and angry. consider this post qualified.
I'll give that a shot with one. Ive boiled one for half an hour and it didnt help. someone on another board recommended freezing them, so i threw the one in the pic (b/c the 2nd ring is still on there) into the freezer to see what happens.
If you're now buying pistons bore the block; around here it's $100 w/o deck plates! 0.004" over is way too much. It will sound like my Cummins diesel & won't last long. AND then you will get to do it all over again real soon if you don't.
Here's a decent set with rings for $164. The FT piston will give you a bit more compression too.
Don't get mad at the guys. They are just trying to save you money and trouble. It cost more to do it wrong and have to do it over than to do it right the first time.
You rings are more than likely rusted and the aluminum of the pistons corroded. All it takes is a little moisture for this to happen. They can be almost impossible to get apart if that is the case and even if you do the ring lands will not seal to a ring again. The rings have to seal to the piston as well as the cylinder wall. That along with the excess clearance is just asking for trouble.
