Big block rebuild
Old Aug 24, 2010 | 09:43 AM
Black76's Avatar
Black76
Default Big block rebuild
I am putting the Big block back together after getting back from machine shop . My question is with the heads does it really matter which head goes on which side and i have heard i need sealent on the head bolt treads is this true
Old Aug 24, 2010 | 09:53 AM
TimAT's Avatar
TimAT
Heads can go on either side- they don't care. And 100% correct- use sealer on the head bolts. I use Locktite thread sealer with teflon, but I've used just about all of the pipe thread sealer stuff from the hardware stores too. Just my opinion, but I don't think that's a good place for RTV type sealers.
Old Aug 24, 2010 | 10:00 AM
baxsom's Avatar
baxsom
Permatex #2 works very well. You will get oil seepage out of the head bolts if you dont
Old Aug 24, 2010 | 11:16 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Double ck if you have a temp sender in one of the heads. That one goes on the driver's side. Not a big deal either way, but getting those pipe plugs out can be a pain sometimes.
So it doesn't matter which head goes where...but it can mess you up if you can't get the pipe plug later.
JIM
Old Aug 24, 2010 | 12:02 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I would also put sealer on the intake bolts, as they can seep oil too.
To Big block rebuild
