cal car killing me
Old Aug 24, 2010 | 01:11 PM
mrl82vette's Avatar
mrl82vette
8th Gear
Default cal car killing me
every time i start this car thiers a new problum check engine light back on ground ecm to get codes key on motor off i get nothing motor on 1flash followed by5 flshes pause 5flashes next headlights go down not up applied vaccum to red line will close them green line wont even register on guage please help thank you Robert
Old Aug 24, 2010 | 02:00 PM
bashcraft's Avatar
bashcraft
Wow, though not a record by any means, that is one long sentence.
Old Aug 24, 2010 | 02:07 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Robert please do us a favor and punctuate your sentences! And also, put a legible title on the thread so we know what we are clicking on.
Old Aug 24, 2010 | 07:00 PM
terry82's Avatar
terry82
what is your question?
Old Aug 24, 2010 | 07:16 PM
mrl82vette's Avatar
mrl82vette
8th Gear
what's wrong with my car, and how do i fix them
Shark Racer's Avatar
Shark Racer
"Hello everyone. Thank you for your time.
I'm getting frustrated by what seems to be an endless stream of issues with my classic Chevrolet. The Check Engine light has recently illuminated, not the first time such a thing has happened, to my consternation. I grounded the ECM to get the codes. With the key on and the motor off, I get nothing. With the motor on, one flash followed by 5 flashes, a pause, and then 5 more flashes.
An additional problem I am facing is that my headlights will retract but not raise under their own power."
Robert - for your headlight problem, I'm betting one or both of the actuator seals is trashed.
Old Aug 24, 2010 | 07:21 PM
mrl82vette's Avatar
mrl82vette
8th Gear
thank you very much, and sorry for the gramatical errors
Old Aug 24, 2010 | 07:46 PM
terry82's Avatar
terry82
a code 15 is a coolant sensor .your headlights have a leak .http://www.corvette-101.com/vacuum.htm#actuator
Old Aug 24, 2010 | 08:00 PM
mar's Avatar
mar
Default Why not just buy a 50 dollar OBDi/II reader?
OBD readers are cheap. Mine has paid for itself a million times already on my car, wife's car, neighbors car - you name it. It will even reset codes.
Oooops - I just looked at your signature - you are pre-OBD, sorry!
Old Aug 24, 2010 | 08:04 PM
terry82's Avatar
terry82
obd 1 readers are getting hard to find and they dont give you much more than the flashes .sears does have one on sale that does read obd 1 and 2 $250.
Old Aug 24, 2010 | 08:12 PM
mikep3's Avatar
mikep3
Default Headl Lights
The head lights have a mile of vacuum hoses, two relays and two actuators. There is no easy fix, replace the hose and check each relay and actuator by disconnecting and put a plug on each connection to isolate each item. Then start connecting, you should be able to find a leak or faulty relay/actuator.
If it is leaking it may effect the engine near or at idle.
"Hows my spelling?"
Old Aug 25, 2010 | 10:38 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by mikep3
..."Hows my spelling?"
Hows is incorrect. Correct is How's since it's a contraction for How is.
To cal car killing me
