10 Spline vs 26 Spline Input
Old Aug 27, 2010 | 09:40 AM
Raptor119's Avatar
Raptor119
Default 10 Spline vs 26 Spline Input
I am debating whether to go to a new supercase Muncie on the rebuild of my 68. If I go that route, the question becomes do I buy the 26 spline or the 10 spline input shaft Muncie. My 68 came stock with the 10 spline tranny/clutch. Simce the clutch will get changed regardless, what is the benefit of one over the other? Is the 26 spline a better design or capable of handling more load than the 10 spline design?
Would like to hear some thoughts.
Old Aug 27, 2010 | 09:49 AM
vetrod62's Avatar
vetrod62
Yes, you answered your own question.
Old Aug 27, 2010 | 10:22 AM
Surfer69's Avatar
Surfer69
26 is much stronger than the 10. More teeth surface area.
Old Aug 27, 2010 | 11:11 AM
TimAT's Avatar
TimAT
I've seen both 10 and 26 spline shafts twisted behind the splines. If you have enough clutch and tires to do that, I suspect it won't make much difference how many splines there are.
Old Aug 27, 2010 | 11:25 AM
gkull's Avatar
gkull
supercase Muncie even with the 26 spline only has a TQ rating of 375 - 400 or so foot pounds and it's biggest downfall is 4 gears. If you have to have a 4 speed the Tex Racing are pretty good. The TKO 500 (also 500 FP) has a wide gear ratio made for lower numeric rear ends and it's 5 speeds
Old Aug 27, 2010 | 02:48 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
A factory Muncie can handle more than 375 ft/lbs of torque. GM called on Muncie's to handle L-88's, ZL-1's, LS-6's, etc,..all of which had quite a bit more than 375-400 ft/lbs of torque.
Add the beefy Supercase which prevents case stretching caused by the angle of the gears, and you have pretty strong tranny.
Yes, she only has 4 forward gears but it only weighs about 75 lbs. If your rig isn't called on for long highway trips, the original Muncie is a great way to go.
FWIW
To 10 Spline vs 26 Spline Input
