under hood light
Old Aug 29, 2010 | 08:59 AM
manfroni's Avatar
manfroni
Default under hood light
my '78 (owned for over 25 years), has never had the under hood light. While doing some engine cleaning, I discovered a wire that is hot all of the time. I am assuming that do to the length of the wire, it is the hot lead for the light. Where would the ground come from and how does light go off, if the wire is always hot? Also, any idea of a kit or a "better" light?
thanks in advance for the help,
Old Aug 29, 2010 | 09:42 AM
mds3013's Avatar
mds3013
Wire is always hot. Ground wire is attached to light socket and grounds to hood support bolt. Inside light there is a mercury switch that turns on/off. mike...
Old Aug 29, 2010 | 10:17 AM
pauldana's Avatar
pauldana
its a ball bearing, not mercury switch. but good description
My question same topic.... where the he!! is the hot wire??? when i got her painted they removed the light and hood for that matter...and I have not been able to locate that blasted wire for the life of me!!!
Old Aug 29, 2010 | 10:34 AM
Wrecked82's Avatar
Wrecked82
What light number goes in there. Mine missing and no manual.
Old Aug 29, 2010 | 10:48 AM
Sean77's Avatar
Sean77
Default bulb #
Larry, the bulb in my 77 simply says 1003 taiwan
Old Aug 29, 2010 | 11:47 AM
terry82's Avatar
terry82
i found my wire hanging in front of where the radiator support is .
Old Aug 29, 2010 | 11:59 AM
...Roger...'s Avatar
...Roger...
No chit , didn't know that. Just learned something !
Old Aug 29, 2010 | 01:19 PM
mds3013's Avatar
mds3013
Well if Roger did not know then I don't feel quite so stupid. Pic. from the '77 AIM. mike...
Old Aug 29, 2010 | 06:57 PM
pauldana's Avatar
pauldana
still looking.... think its hiding...
thought the sam thing until i cleaned it.... the BB sometimes gets dirty and needs solvent squirted into the socket to clean it...
hey... you by no means have the marked cornered on stupid... I own most of that real-estate!!
To under hood light
