Dead BATTERIES
Old Aug 29, 2010 | 06:20 PM
bholub's Avatar
bholub
3rd Gear
Default Dead BATTERIES
Problem: I have a 1980 that keeps running down batteries. I drive it about 5 times/week, probably about 25 miles/week. About every month or so, the battery dies. I replaced the alternator last month (tested the one I took off the car and it was fine too) but that didn't work because it has died since. I was told possibly the courtesy light timer could be causing this or even the headlight switch. There are no unusual noises/lights that stay on longer than they should. Anyone experience this??
(the same car also has this problem... http://forums.corvetteforum.com/c3-t...ring-jerk.html)
Old Aug 29, 2010 | 07:56 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Get a battery disconnect switch until you find the problem. They also make it easier when you need to work on the car.
Old Aug 29, 2010 | 08:03 PM
BHRIG's Avatar
BHRIG
Is under hood light staying on?
Old Aug 29, 2010 | 08:29 PM
72LS1Vette's Avatar
72LS1Vette
You need to connect an amp meter between one of the battery terminals and the cable. You will most likely see a current draw. Then remove one fuse at a time until you see the draw stop. You can then remove one component at a time from the offending circuit to find out which component is causing the problem.
Rick B.
To Dead BATTERIES
