Engine dies - fuel or ignition?
Note: ignition was serviced about 4 months ago - new points, condenser, distributor cap, and new shielded wires. No problem since then - until this occurred.
Ideas?
Symptoms - wet sooty plugs, gas dripping in primaries of carb at low rpms.
Crank engine and look closely in carb as its running, looking for the primaries dripping gas. At high rpms the engine can burn the excess gas but not at low rpms.
Be careful not to get your head directly over the carb while its running in case it backfires. Saw my dad get his face burned that way when I was a kid.
Roger
One (or more) of those is not right. Without more clues, everyone is just shooting in the dark and hoping to hit something. For instance, when it does fire after a stall, does it puke black, stinky smoke out the pipes? If it does then that could point to an over-fueling condition that is loading up the plugs and killing the engine. For this you'd want to make sure the idle air bleed is clear since it is easy to get some carb cleaner with the straw and force some solvent into the emulsion to clean it out. If it was the filter, higher-speed or high-load failure would prevail. Underfueling (clogged filter and such) rarely shows up a low speed, low load such as at idle. But it could if the idle fuel restrictor or the idle channel was dirty and it's not getting enough fuel in the idle circuit. You'd also have to look at a severe vacuum leak since this can greatly upset the idle -particularly if it is on the lean side.
For the ignition, you'd want to make sure your points have not closed up. Poor low speed behavior is common with excessive dwell.
The squeeze and blow parts are harder to diagnose. If the cam timing has retarded due to a loose chain, it will cause low cylinder pressure at low engine speed. You'd have to do a compression test to see if you have appropriate compression. There are other issues here, but that's just one of the more common ones.
As far as the blow, that would be a restriction in the exhaust (had wasps build a nice dam in my exhaust once) but that would be a high-engine speed issue.
It didn't seem to be flooding in my case, no strong gas odor or black smoke. Acted like it was starved, possibly the idle circuit clogged as someone mentioned. My filter is clean and the carb was completely rebuilt, parts plated, new components where needed, etc.
I thought maybe some water in the tank. Car was sitting for several months, some very hot humid weather. Thought maybe with gas sloshing around in the tank it may have sucked up some water.
Tossed a can of dry gas in the tank.
I also discovered I had the wrong coil installed. One for transistor ignition, so I replaced it with the proper one. Not sure which of these may have made a difference. Haven't had the problem recur so far.
If you find another cause I'd like to know. I'm not completely convinced all is well with mine, not having hit on any one fix which definitely fixed it. So far OK, waiting to see if the problem has truly been solved.
I know what fv69 means ... but it really ain't the points lobe that noticeably wears ... instead, it's the fiber or plastic follower riveted to breaker arm that wears.
More "shooting",..I'd look first at the ignition system. A cracked distributor cap can cause the symptoms you describe. Also, make sure the big lead from the coil to cap hasn't worked it's way a bit loose. Also, it's my experience that coils either work or they don't. I've not found them to 'sort of work', but I've been fooled before. Check for good stable voltage to the coil.
If the ignition checks out, take a look at the fuel system; clogged filter, crimped line, bum fuel pump. Although, with fuel supply problems, it's usually higher RPM's that suffer; not lower.
Good luck with your trouble "shooting".
