simple (for someone) rear end question
Old Aug 30, 2010 | 01:30 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Default simple (for someone) rear end question
i did the usual google search and searched the tech forum here, but can't really decide if i got my questions answered regarding the original options for rear end ratios and whether there was a difference between the standard rear end ratio for the automatic trans versus the 4 speed (closed ratio M20) trans without opting for the high performance option. it appears there was a "high performance" rear gear option, but i can;t find information as to whether that was an option available to both or just the 4 speed and what the various "standard" and "optional" rear end ratios were.
can someone provide a link to the proper information or perhaps a cut and paste of it here??
the reason for my inquiry is that i am converting my 78 automatic to an OEM 4 speed (M20) and would like to know if i can use my current posi rear or if there was a standard 4 speed rear that was used at a bit lower ratio other than the optional one??
many thanks
Old Aug 30, 2010 | 01:45 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Differentials were the same. All are Posi. AT would have had the 3.08:1 ratio. 4 spd would have been 3.36:1. 3.55 and 3.70 were availabe for the 4 speed.
Old Aug 30, 2010 | 02:13 PM
BKarol's Avatar
BKarol
M21= Closed ratio not the m20
If you are looking for the standard choice then:
L48 4spd (2.85 low) Std 3.36
L48 auto = 3.08 & 3.55(above 4000 feet altitude)
L82 4spd (2.64 low) Std 3.70 & 3.36 (below 4000 feet)
L82 4spd (2.43 low) Std 3.70
L82 auto Std 3.55.
With that said these are the standards. Someone on this forum has a closed ratio 78 M21 and he opted for a different rear end than 3.70 and got it.
You should write to Hunt4cleanair and ask him to send you the write up he did about the 4spds. Very informative.
I got my info from the 78 Restoration packet (specifications).
Old Aug 30, 2010 | 03:38 PM
srs244's Avatar
srs244
thank you both for the very informative input. i greatly appreciate your help. i guess my problem now will be what it will be like using the 3:08 rear on a 383 stroker (.30 over with a mild cam and approx 9.5:1 compression). i assume the low end will be pretty weak, but the cruising speed will be at lower RPM and will produce better MPG. opinions regarding the trade off???
thank you again
steve
Old Aug 30, 2010 | 04:32 PM
gerry72's Avatar
gerry72
A true close-ratio Muncie (M21 or M22) and a 3.08 rear gear gives you a 6.75 ratio at the axle. Unless this car has some phenomenal low-rpm torque and you are using a 35-40lb flywheel, it will not be an easy car to get off the mark. Generally recommended target for the axle is 9:1 for a street-driven manual trans car. A wide-ratio Muncie (M20) with it's 2.64 1st gear gets you acceptably close a 8.1 and the car will be fine if the engine doesn't sacrafice much low-rpm torque and you use at least a 30lb flywheel.
Unfortunately, an engine build is more than just pistons pushing on rods and rotating the crank. You also have to consider what the crank is turning and this would include an appropriate transmission and final drive. Others who have made a mistake in the rest of the drivetrain can relate how little fun driving such a mismatched colletion of parts can be.
It's hard to gauge your outcome since a "mild cam" covers a lot of ground.
Old Aug 30, 2010 | 06:29 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Handy link below lists available power teams, but there's no rule which says you have to adhere to it...
http://carburetor-manual.com/libro/1...tion-Guide.pdf
Old Aug 30, 2010 | 08:40 PM
srs244's Avatar
srs244
thanks. i do agree i was a bit vague (only because i don't have the cam spec sheet in front of me. about all i remember without it is that it's a comp cams model (and i seem to remember it's a 70 degree model), but that may be all wrong, lol. my intention is to better match the components of the drive train (the original reason i asked the questions). the engine when completed is expected to produce well over 350 HP and more than adequate torque, lol.
thank you for the help and insight.
Old Aug 30, 2010 | 08:41 PM
srs244's Avatar
srs244
thank you for the link. most informative and a good reference.
Old Aug 30, 2010 | 09:36 PM
68/BB's Avatar
68/BB
Now I am curious about my combo. My '68 came with a 327/300, a four speed and it has the original rear end marked as a 3.70. Is that an unusual combo? What are the chances my 4 speed may be an M21 vs. an M20 (given that rear end)? My tranny is original but I dont know if it is M20 or M21. This is a great thread, thanks for starting it.
Old Aug 30, 2010 | 09:40 PM
meinthe73's Avatar
meinthe73
Are you saying all diffs have a locker? That would be sweet
Old Aug 30, 2010 | 09:51 PM
srs244's Avatar
srs244
here is a great reference on 4 speed transmissions, etc. many thanks to hunt4cleanair for his work.
http://www.hunt4cleanair.net/
Old Mar 31, 2020 | 02:05 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Once upon a time, long, long ago, I thoroughly enjoyed 3.70, 4.11, 4.56 gears in my cars (and gas was $.23-.25cents/gal). But now I've switched to rears with 2.41, 2.73, 3.08 ratios. Of course, my cars have 4-5spds with a low 1st gear and engines with plenty of torque, which results in virtually no feathering of the clutch------------------------------NO, none of my cars have auto trannys! so the combinations work just fine. The big plus is much lower rpm on the Interstate. Back in the days of .23-.25/gal gas, the term Interstate hiway did not even exist!
Old Mar 31, 2020 | 02:21 PM
jb78L-82's Avatar
jb78L-82
10 Year OLD THREAD!!!!!!!!!!!
To simple (for someone) rear end question
