1970 Hood Clearance
Old Aug 30, 2010 | 07:17 PM
LouAZ's Avatar
LouAZ
Default 1970 Hood Clearance
I’d like to install a new hood that will give me a bit more clearance.
I currently have a 1973-75 style hood and what I think is a 1970 front end. Although the car is a 1970, the guy who built it grafted on a 1974 nose and rear to make it look like a 1974. I have no idea why. It’s got a big block with an edlebrock 1904 carb. With the 2” air filter it presses right up against the underside of the hood.
I might like to go with a 1970 style big block hood to give me the extra clearance but do not know if it will fit. Ecklers has hoods for 68-72 and 73-76 but I am not sure if they are interchangeable
Any advice would be appreciated
Old Aug 31, 2010 | 09:42 AM
bashcraft's Avatar
bashcraft
Do you have a wiper door?
Old Aug 31, 2010 | 10:44 AM
LouAZ's Avatar
LouAZ
I don't think so. The hood ends and the wipers are partially recessed under the hood. There is nothing that looks like a door.
Old Aug 31, 2010 | 10:50 AM
bashcraft's Avatar
bashcraft
Then you need to use the 73 & up hood.
Old Sep 1, 2010 | 11:36 AM
LouAZ's Avatar
LouAZ
Thanks very much for the info
To 1970 Hood Clearance
