LED-Tunsignal issues
all working great. until i installed and tested the hazard flasher.
I traded all (2 hazard and turn signal) flashers form stock to heavy duty electronic flashers.
before, they flashed (in either left or right turn signal mode) perfectly, just the right brightness etc.
now with the hazard flasher in, with the headlight switch all the way off, no parking lights, they flash quickly and very very dim.
pulled out the hazard flasher and not the once prefect turn signal operation, now does the same, fast flash and very dim.
Also in the 78, when do the drop signal light come on? are they running lights? turn signal only? because they dont come one at all and bulbs are good.
HELP!!!!
If you remove the hazard flasher does everything work OK now ?
1. headlight switch off
turn signal left and right...front marker and front side markers and rear tail flash, rear side markers, no flash
2. hazards on
front marker and front side marker and rear tail flash, rear side marker, no flash
3. headlights/running lights on
front markers on, front side markers off, rear tail lamps on, rear side markers on
4.headlights/running lights on
turn signal left and right, no flash...light on and steady just as if the headlights are on with running lights but not turn signal activated...
more head scratching....
http://shop.advanceautoparts.com/web...ci_sku=5081289
