Valve Adjustment.... Will This Work ?
Old Mar 28, 2002 | 09:43 PM
Richard Cooper's Avatar
Richard Cooper
Default Valve Adjustment.... Will This Work ?
I have all the rocker arms off and the rods out of my 81, I just replaced the seals. I put a rod back into the lifter and let it just stick out, now I turned the engine over with the crank nut and watched the rod come all the way up and then go down. After it stopped going down I turned it just a touch more to make sure it was all the way down. Now I put the rocker arm back on and adjusted the valve by turning it inbetween my fingers and tightening the nut till I felt a difference, then turned the nut 3/4 of a turn more. I know this is the long way to do this but I really feel comfortable doing it this way, if it will work.
Thanks for any help.
Old Mar 28, 2002 | 11:05 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Valve Adjustment.... Will This Work ? (Richard Cooper)
this will work but you can do it in 2 steps. TDC#1 ex 1-3-4-8 int 1-2-5-7 TDC#6 ex 2-5-6-7 int 3-4-6-8 do not install the TDC#6 pushrods till you finish the TDC#1 first. :chevy
Old Mar 28, 2002 | 11:37 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: Valve Adjustment.... Will This Work ? (clem zahrobsky)
Yup. What clem said. Rather than remember that order, what i typically do is start with the engine at TDC #1. Adjust #1 & rotate the engine 90 degrees. Then do #8, another 90, then #4, etc....3,6,5,7,2....
Takes a little time, but 1-8-4-3-6-5-7-2 is burned into my brain much better than 1-3-4-8, 1-2-5-7 / 2-5-6-7, 3-4-6-8.
What you're doing will work, but it seems a bit lengthy.
Dave
Old Mar 29, 2002 | 12:56 AM
63Banshee's Avatar
63Banshee
From: WANTED: '68 rear valance with b/u light assemblies IM, e-mail, or PM me here. Thanks!
If that works for you then why not place all the push rods in position and mount the rockers for all the push rods that are down at a give point? This would save you time and would cut down on the number of times the motor is turned dry by the crank bolt… which isn’t recommended.
Old Mar 29, 2002 | 02:48 AM
Rockn-Roll's Avatar
Rockn-Roll
Default Re: Valve Adjustment.... Will This Work ? (63Banshee)
Like 63Banshee said...many mechnics assemble the entire valve train, then tighten down the valves while spinning the push rods until there is resistance in the push rods.
Old Mar 29, 2002 | 09:43 AM
mrvette's Avatar
mrvette
Default Re: Valve Adjustment.... Will This Work ? (ddecart)
72184365 is the firing order....
so that has allmost nothing to do with adjusting valves...
but I find the heel of most cams is nearly perfect in grind so for most degrees of rotation there is so small a variation it just not important enough a variation...so I manage to flip crank just 180 deg. once is enough to get them all....I"m lazy I know....but they run fine...I do 1/2 turn after friction felt on push rod....
not for solid lifters, it's more ciritical....
GENE
clem zahrobsky
Cruise-In I Veteran
that what my way does you do all the lifters that are down,8 on TDC#1, and 8 on TDC#6. if you put all the pushrods in and turn the engine you came collaps some lifters and they will not come back so when you adjust them they will be too tight :chevy
Old Mar 29, 2002 | 10:37 AM
dladd74roadster's Avatar
dladd74roadster
Default Re: Valve Adjustment.... Will This Work ? (mrvette)
The firing order does have something to do with it. If you start off with #1 at TDC, you can adjust the intake and exhaust valves for that cylinder. When you turn the crank 90 degrees that brings 8 up to TDC and you can adjust them. In order to do it this way, you have to know the firing order and you have to KNOW that the valves aren't going to be open when that cylinder fires so BOTH the intake and the exhaust lifters are going to be on the base circle of the cam.
dl
Old Mar 29, 2002 | 05:39 PM
mountainmotor's Avatar
mountainmotor
MrVette,
18436572 is the Chevy firing order.
Quote:
" would cut down on the number of times the motor is turned dry by the crank bolt… which isn’t recommended."
It is only twice around with a presumably well assembly lubed"not motor oil" assembly excepting the cylinder walls and not under any type of a load as compared to cranking or actual running.Every motor I have ever built has been rotated this way.Also gives you a chance to see if you were on TDC #6 or TDC#1 when you started by checking the previous set rockers for the obvious ultra loose ones.The small Chevy is not as easy to see the cam lobes as a BB is when the cam is installed.
Clems way can be done as well .
_______
Old Mar 29, 2002 | 09:48 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: Valve Adjustment.... Will This Work ? (mountainmotor)
This was the way I was told to do it. For a perforamnce cam it is important to be on the heel of the cam. FIrst loosely install all rockers. To find the heel for number 1 cylinder you look at cylinder 6. THe point where exhaust is closing and the intake begins to open is overlap and that is when you want to adjust the valves on number 1. Then go to number 8 and look at cylinder 5 and so on in this pattern:
1 8 4 3
6 5 7 2
Any comment on this is fine as I have not yet tried it but will be doing it soon :D
Old Mar 29, 2002 | 11:49 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Default Re: Valve Adjustment.... Will This Work ? (dladd74roadster)
dl
Actually, the igntion firing order isn't a factor. The issue is valve events in relatin to piston position and not firing events. Other engines use the same crankshaft/camshaft relationship but with a different firning order and the same valve adjustmet sequence still applies.
Old Mar 30, 2002 | 12:30 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Re: Valve Adjustment.... Will This Work ? (MotorHead)
1 8 4 3
6 5 7 2
I'm with Motorhead on this one. Just went through all this Weds and set the zero lash on the push rods on the cylinders in sets as he mentioned. Blocked in all accessory vacuum, disconnected A.I.R. pump, then idled motor and backed off each rocker til it clattered, then tightened one full turn in 1/4 turn increments with a short pause in between til motor smoothed out and did each valve this way-motor super quiet and smooth!!! This way worked for me!!! :yesnod:
To Valve Adjustment.... Will This Work ?
