What's this plug into?
Old Sep 1, 2010 | 06:54 PM
JB46's Avatar
JB46
Default What's this plug into?
So the car is a 75, w/L48 auto transmission. Bolted on my intake manifold, driver side rear near #7 is what appears to be either a capacitor or perhaps a signal filter/noise arrestor. It has a single orange wire, with a connector on it. What does this plug into? Thanks in advance for any help
Old Sep 1, 2010 | 08:42 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
"tach filter"
It's normally in line with the tach wire coming through the firewall.
Look at the distributer and see if there's a plug in the "tach' spot. The tach wire should plug into one end of the filter and the other end of the filter should plug into the "tach" spot on the distributer.
Tach will usually work without it.
Old Sep 1, 2010 | 08:59 PM
JB46's Avatar
JB46
The Tach filter is plugged in. This plug doesn't reach the distributor. Their is only one wire out of this 'filter' nothing out the other side.
Old Sep 1, 2010 | 09:12 PM
KapsSA's Avatar
KapsSA
Hmmmm, wondered about the orange wire as the original would be brown.
Is it bolted on to the intake right where the intake manifold runner says "7"?
Old Sep 1, 2010 | 09:23 PM
JB46's Avatar
JB46
Yes...The plug looks like it was mfg.to plug into the distributor. It's about 2-3" from reaching it though. Like I mentioned, bolted directly to the intake manifold where it says 7, one single wire from it to it's plug. Looks like a noise suppressor except for the single wire.
Old Sep 1, 2010 | 10:14 PM
snoopykissedlucy's Avatar
snoopykissedlucy
Here's a pic of my unmolested 1976 Corvette. Look carefully underneath the metal brake booster line coming out of the carb, the filter is bolted at this point. Its possible that your tach filter was rebolted in the wrong position.
Old Sep 1, 2010 | 10:51 PM
KapsSA's Avatar
KapsSA
The tack filters in all 4 of my Vettes, altho 78/79s, are bolted to the intake manifold right next to the "7".
Perhaps someone just left an old one in place?
To What's this plug into?
