Electric Fans/ Taurus Conversion
The 12in is supposed to flow 675cfm and the 10 500. Is it worth it to upgrade to the taurus fan. I have a new stock radiator with all seals and spoiler in place. Or would it be best to make a shroud for these fans. Thanks
To cool your engine, you need about 2600 cfm air flow in the hardest conditions. So, you are far from this number with your current setup.
Most people don't use a fan shroud when using a Taurus fan because it's generally not needed ( it's one of the most powerful fans available, about 3000 cfm ).
By doing so, it will only cool the radiator area corresponding to its diameter. However with a new radiator core, it should be more than enough.
Also, remember that the Taurus fan is heavy and vibrates at full speed, so I wouldn't attach it through the radiator core, but with strong brackets.
If you're interested, I made my own fan shroud with two 12" ( 2 x 1330 cfm ) SPAL fans http://www.spalusa.com/pdf/30101522_SPEC.PDF#view=FitH :
http://forums.corvetteforum.com/c3-t...-progress.html
http://forums.corvetteforum.com/c3-t...-pictures.html
http://forums.corvetteforum.com/c3-t...l-chapter.html
There is something else you could try first, except if you already did it :
If your distributor has a vacuum advance canister, hook it to full intake manifold vacuum instead of the ported vacuum carb fitting.
This will help cooling the engine at idle. Believe me, it's very noticeable, and this improvement costs nothing.
If you plan on keeping stock fan and adding the 10 and 12 infront of radiator it should help a bit. If removing stock go with the biggest dual setup or a 18" with over 2600cfm. also wire it where it is on a temp sensor wired to a constant hot, so when the car is shut off it will still run and cool the motor after being driven.
hope this helps..
hope this helps..
However, just a quick question : Do you use the stock copper radiator or is it aftermarket ?
You can see from the 1st pic, the fan covers the core very well. This rad is for a '66 427 car.
The bolts are countersunk/flat faced & I countersunk the aluminum brackets on the opposite side so they wouldn't touch the radiator core. If you look closely, you can see the holes for riveting to the radiator hat. I trimmed the plastic tab off the top of the radiator since it no longer served a useful purpose.
Foam rubber detail.
You will want to trim away the overhang from the AL brackets. In my case, a sharpie and a jigsaw with a metal blade did the trick nicely. Foam rubber from Home Despot seals the sides.
Fan, brackets, foam rubber, hardware = $40 a couple of years ago. I flow tested the fan and it flows right at 2000 cfm (the Mark 8 only flows about 200 cfm more) Be sure to conect power to only the high speed wire. If you run power to both the low and high speed wires, you will burn up the motor.
I have a new 4 row radiator so its thicker than before and it looks like if it were a inch thinner i wouldn't have had any issues?
I dropped the sway bar down for now,but just wondering if there will be clearance issues putting it back up once the rad is in place?
