control valve help
Old Mar 28, 2002 | 10:44 PM
schetk's Avatar
schetk
2nd Gear
Default control valve help
Please help. I am a new user to the post and am rebuilding a 72 PS control valve with a kit from Mid America. The schematic is pitiful, can't tell a seal from washer on the diagram. I went to Zip products and they had the same one.
I am getting a leak of PS fluid from the ball stud grease fitting and seams from the ball stud seal. I mean a serious leak, after it warms up and I turn the wheel back and forth with the wheels in the air. I went back thru the valve and seem to have everyting in order but, I don't see where a # 18 "ring" seal goes or if I have one (mid america say's none included). Also I can't seem to get the back up washer on between the annulus seal and annulus spacer? If I put it on, the valve housing will not get tight with the adapter housing.
Old Mar 29, 2002 | 12:46 AM
Scott78's Avatar
Scott78
Default Re: control valve help (schetk)
I can't help you on this Kevin but at http://www.corvettefaq.com the have a 5 part
rebuild article. I's in the steering/suspension area.
Welcome to the forum
Scott
Old Mar 29, 2002 | 10:52 AM
phoenix's Avatar
phoenix
Default Re: control valve help (Scott78)
I rebuilt mine with the kit from zip and still had a leak around the ball stud. The ball itself was dented in and I wasn't going to spend another $30 on the ball stud rebuild kit. I sucked it up and bought one of their rebuilt ones. Best $79 I spent. It is centered, doesn't leak etc...
I too had the problem with the diagrams. It helps a lot if you lay out each piece as you take it apart so that you can duplicate it as you put it back together.
Good luck.
Old Mar 29, 2002 | 11:19 AM
schetk's Avatar
schetk
2nd Gear
Thanks Scott and Phoenix. I will try the new diagram in FAQ this weekend, If it still does not work I will probably get the rebuilt unit.
To control valve help
