starting problem
Old Sep 4, 2010 | 12:10 AM
jaa1602's Avatar
jaa1602
1st Gear
Default starting problem
just recently ripped out the wiring and put it all back in, not sure if i got everything though. Well now the car wont start, turn over, or anything except the tung sol module that would be behind the speedo is buzzing.
Its not the battery or the fuses
Old Sep 4, 2010 | 07:56 AM
dannyman's Avatar
dannyman
Check to see that you have power at the starter solenoid. If not; check neutral safety switch or clutch safety switch depending on your car system.
A bit more information would be helpful.
ie: Do you have any power to headlights, radio, gauges, etc?
How much wiring did you "rip out"?
