Creeking noise when I turn left???? help
Old Sep 4, 2010 | 02:52 PM
mikecc's Avatar
mikecc
Default Creeking noise when I turn left???? help
What would all of a sudden start to make like a "creeking" noise when I turn left??? does it really bad at a slow turn.. not so much a fast turn.. car still drives fine and everything.. any direction on where to look will be greatly appreciated....
Old Sep 4, 2010 | 02:59 PM
pewter-FRC's Avatar
pewter-FRC
dont turn left...ill be here all week!
Old Sep 4, 2010 | 03:02 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
Direction? I'd say go straight to eliminate the problem. If that doesn't work, try bouncing the car and check shocks, springs, bushings.
Old Sep 4, 2010 | 05:04 PM
mikecc's Avatar
mikecc
OKAY..LOL its more like a popping noise or like metal on metal rubbing for a short time
Old Sep 4, 2010 | 08:53 PM
mikecc's Avatar
mikecc
seems to start after driving car for awhile.. does not do it cold?? like I said seems more of a popping noise but I don't feel anything in the steering wheel???
Old Sep 4, 2010 | 09:00 PM
my 76 ray's Avatar
my 76 ray
Is it coming from the front or rear?
Old Sep 4, 2010 | 09:57 PM
mikecc's Avatar
mikecc
front passenger
Old Sep 4, 2010 | 10:15 PM
dannyman's Avatar
dannyman
When was the last time you had a front end lube?
Suspect ball joints.
Old Sep 4, 2010 | 10:21 PM
my 76 ray's Avatar
my 76 ray
OK. It's coming from the passenger side, so i would check the wheel bearings on that side.
If that isn't it, then my questions would be:
Is it a continuous pop pop pop or a single pop?
Does brake on/off make a difference?
If you continue to drive in a circle does the noise stop or does it stop when you start to return the wheel to straight?
Old Sep 4, 2010 | 10:39 PM
mikecc's Avatar
mikecc
stops when i go straight.. its not continuous either starts when you start to turn the wheel once you stop turning wheel the noise stops too again only left wheel turn and only after driving awhile,, has me puzzled
Old Sep 5, 2010 | 05:15 AM
mysixtynine's Avatar
mysixtynine
Creaking noises almost always indicate worn control arm bushings or dry ball joints or dry tierod ends.
Grease your ball joints and tierod ends.
If not then spray some silicone oil on the front sway bar bushings where they mount it to the frame. Seen them moan when get dry and worn out.
Old Sep 5, 2010 | 07:24 AM
OzzyTom's Avatar
OzzyTom
I have had isues with "creaking" noises when turning after spirited runs....
in my case, it was due to diff chatter. The friction plates in the diff got warm, and the diff oil gets less slippery as it becomes hotter, and at slow speed turning the plates lock momentarily and release suddenly as left and right wheel speeds differ on turning. This was after a diff rebuild.
Changed the diff oil, added LSD additive and problem solved.
Now in your case, it may be totally unrelated to the diff.
Just giving you a heads up on another possible cause if you don't locate the problem in the suspension.
cheers
tom
Old Sep 5, 2010 | 12:19 PM
Mr.Gearhead's Avatar
Mr.Gearhead
Maybe a Steering box? Do you feel anything the steering wheel? Car have P/S?
Jack the side up and pull on the tire top to bottom and then left to right... does it move in anyway? Could be what others mentioned... Really need to start ruling items out to find the culprit.
To Creeking noise when I turn left???? help
