Engine Gurus??
Old Sep 5, 2010 | 02:46 PM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
Default Engine Gurus??
I'm am not a mechanic by any means. But, I know you guys will know what's up.
I've got a "ticking" when accelerating, it disapears when I get up to speed(any speed).
Any help is greatly appreciated.
Old Sep 5, 2010 | 03:57 PM
KSM's Avatar
KSM
Do you hear this ticking at idle or when revving the engine in park??
Old Sep 5, 2010 | 04:13 PM
BBCorv70's Avatar
BBCorv70
By ticking could you be referring to detonation (pinging). Does this only under load or hard acceleration? If it is, maybe try running higher octane gas.
Old Sep 5, 2010 | 04:16 PM
1996Z15's Avatar
1996Z15
Perhaps a small exhaust leak; I would think the "ticking" would be heard as you're accelerating and would settle down as you get to cruising speed.
Old Sep 5, 2010 | 05:43 PM
jbaron's Avatar
jbaron
Can't really hear it at idle. Only acc. Sounds like it's coming from the distributor area!
Old Sep 5, 2010 | 06:47 PM
firstvett69's Avatar
firstvett69
Default ticking,?
If the ticking noise is under acceleration only and not at cruse, and a little at idle. I think it is a simple exhaust leak, had one of my smog pump plugs on the exhaust manifold fallout the other day. at idle slight ticking, during acceleration constant ticking, backing off or at cruse no ticking. How to track it down, engine running hood open Rev engine by hand at carb if it is an exhaust leek you will be able to hear it and find it easy this way. GOOD LUCK. firstvett69
Old Sep 6, 2010 | 09:38 AM
jbaron's Avatar
jbaron
ttt
Old Sep 6, 2010 | 09:47 AM
mashinter's Avatar
mashinter
Very carefully feel for an exhaust leak at idle. You may be able to feel the exhaust gas leaking even if you can't hear it.
Old Sep 6, 2010 | 06:52 PM
jbaron's Avatar
jbaron
Thanks guys. Any other ideas?
Old Sep 6, 2010 | 08:56 PM
wiseman79's Avatar
wiseman79
Likely an exhaust leak like others have said. I had one for a couple years I couldn't track down. When I removed the headers it had a small hole on the inside area of the pipe that faced the engine and could not be seen while they were installed. They can be tough to find but that's what it sounds like the problem is.
Old Sep 9, 2010 | 10:18 PM
jbaron's Avatar
jbaron
ttt
To Engine Gurus??
