Lower Shroud Bracket - 1968 Only?
Old Sep 6, 2010 | 02:23 PM
Clams Canino's Avatar
Clams Canino
Default Lower Shroud Bracket - 1968 Only?
Am I correct that this bracket I'm searching for is a(nother) 1968 only part?
It's one of the L shaped lower brackets for a 1968 radiator shroud. It attaches to the large radiator lower baffle pan with one bolt and no nut. There are 2 per car.
Please note that It's not iether of the L shaped brackets that weld to the shroud, but rather the part that those welden on brackets bolt to in the lower baffle.
-W
Old Sep 6, 2010 | 04:05 PM
1971corvette's Avatar
1971corvette
I believe I have the same brackets on my 71, I had a long search in finding them,and then switched to an electric fan.
A left and a right side as they are different lenghts due to the motor not sitting in the center of the car.I have part numbers also they are as follows 3974661 (drivers side) and 3974662 (passenger side) both of mine have a bolt and nut on each end of each bracket.
Maybe these are different then 68s ?
before someone asks for them I am holding on to them, all parts will go with the car if the buyer wants them.
Old Sep 6, 2010 | 04:15 PM
Clams Canino
The '68 are held on with just a bolt because the nut is welded to the lower baffle pan.
They might be the same brackets - might not. A pic would help.
-W
Old Sep 6, 2010 | 04:25 PM
1971corvette
send me your e-mail and I will send you pics of what I have for mine
How do they look ?? think they are correct or not ?
Old Sep 6, 2010 | 05:44 PM
Clams Canino
Email received thanks!
They are not correct. The '68 ones look like a piece of flat stock with a right-angle bend and a hole on each side. 1" on the pan side 2 1/4 where the shroud would bolt to it. No ridges or anything. Just flat steel with a bend and 2 holes.
-W
Old Sep 6, 2010 | 09:37 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
-W
Clams-
Actually the bracket GM p/n 3919746 was used in both 1968 and 1969. I just had a car in the shop last week with these I wish I'd have taken a picture.
They are just 90 degree bent flat stock. There are two oval holes in them and the top one runs left to right the lower one up and down. I think there is a good pic of this in the AIM. +
I'm not positive, but the brackets are the same width as the one that comes off the bottom of the fan shroud. I'm assuming you have the metal "Drum bottom" shroud too..
In 1970 the design was changed to a completely different bracket.
Hope this helps.
Willcox
Old Sep 7, 2010 | 02:59 PM
Clams Canino
Originally Posted by Willcox Corvette
Clams-
Hope this helps.
Willcox
Yes, that's them. Thanks!!
You need to get some made - so you can be the only vendor that stocks them - what say??
-W
Old Sep 7, 2010 | 06:26 PM
0Willcox Corvette
Former Vendor
Clams-
Not a bad idea. When I get the 78 and 81-82 stripes done, I'll look in to it.
W
Old Sep 7, 2010 | 06:44 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Need one also.
Old Sep 7, 2010 | 07:44 PM
Clams Canino
As I understand it now they were used (at least) in all 68-69 small blocks without AC.
-W
Old Sep 7, 2010 | 09:00 PM
0Willcox Corvette
Former Vendor
you are right.. all with a metal shroud 1968-1969 used two of them.
Budman.. if you have one.. I'll use it for a pattern and make a few. Shouldn't be that hard for me.
Old Sep 7, 2010 | 10:54 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
No problem. I'll see how easy it is to remove tomorrow night. I can probably temp up something with scrap to hold the shroud in place while you do your take off. PM me where you want it mailed and to who's attention.
Old Sep 7, 2010 | 11:44 PM
Clams Canino
When you get it off... can you post a pic of it please?
-W
Old Sep 9, 2010 | 11:49 AM
Clams Canino
Did this happen? Mine is free to send for a bit as well.
-W
Old Sep 9, 2010 | 12:19 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
-W
They haven't contacted me yet.
Old Sep 11, 2010 | 07:54 PM
0Willcox Corvette
Former Vendor
Hey Guys..
Sorry, I've been out for few days.... Which ever one of you wants to send me one...
I'd be glad to give this a shot! Please send it to the address below and mark something on the box "IMPORTANT".
Send it to:
Willcox Inc. Attn: Ernie
123 E. Maple Street
Jeffersonville, Indiana 47130
Old Sep 17, 2010 | 12:09 PM
Clams Canino
Budman... I sent mine in yesterday.
-W
To Lower Shroud Bracket - 1968 Only?
Old Sep 17, 2010 | 11:34 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
-W
Thanks, W... Buddy S.
Old Oct 1, 2010 | 10:55 PM
0Willcox Corvette
Former Vendor
Ok.. I have them completed.. In stock and ready to ship.
I'm adding them to the site right now.... Clams.. ditch the free hand pair I sent you.. these are nice.... and I'll have your original and the extra one sent out on Monday morning.. N/C
Ernie
Old Oct 1, 2010 | 11:00 PM
Clams Canino
As I suggested - make sure you market them WITH the mounting hardware.
There is no way to lose that bracket without losing the 5-16th hardware too.
You'll make a few extra bucks per order - and do the owner a great service at the same time.
-W
