Hood clearance question
Old Mar 29, 2002 | 12:15 PM
mefreema's Avatar
mefreema
Default Hood clearance question
I am looking into getting a Performer RPM intake manifold and I know they are a slightly taller manifold that the Weiand duel plane I am running now. I also have a Nitrous plate in there as well. Will I have a hood clearance issure with the edelbrock performer RPM manifold? If so what can i do about it. I am currently running a 14X4 air cleaner I think so I could always go down to 14X2 I guess. Depending on when I can get a new carb I may even need to run an adapter plate for a short while too.
Old Mar 29, 2002 | 12:25 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: Hood clearance question (mefreema)
I run with the performer rpm intake and a K&N filter on my BB-73.That didnt fit under the hood ,so i vent with the L88 hood..It looks :cool: :cool:
Old Mar 29, 2002 | 12:48 PM
Monkeywrench's Avatar
Monkeywrench
I also have the preformer with a 4" air cleaner but with an L-88 hood. I don't think it would clear with a stock hood...
Old Mar 29, 2002 | 12:51 PM
villare's Avatar
villare
Default Re: Hood clearance question (BB wowbagger)
hey BB wowbagger do you have any more pictures from different angles of your vette with this hood it looks pretty good
Old Mar 29, 2002 | 02:12 PM
Monkeywrench
Default Re: Hood clearance question (villare)
I have the same hood. Here's a photo. I have more if you want to see different anles...
Old Mar 29, 2002 | 02:49 PM
john's '81 mouse's Avatar
john's '81 mouse
Peformer RPM won't clear stock hood on your '79, if you are running stock height air cleaner/filter assembly, and it really won't for you since you also have the NOS plate. You'll have to go with a drop base air cleaner set up if you want to run this combination with a stock hood.
Old Mar 29, 2002 | 03:15 PM
jerryjfunk's Avatar
jerryjfunk
Default Re: Hood clearance question (john's '81 mouse)
So that means a Weind duel plane intake will fit fine under my stock 79' hood without getting a 2" air cleaner, right?
Old Mar 29, 2002 | 03:21 PM
mefreema's Avatar
mefreema
So I could get away with performer rpm intake, nitrous plate, with drop base 4 inch air cleaner. If I have to go down to a 2in or 3in if they make them air filter will that effect my performance much or not enough to really worry about?
Old Mar 29, 2002 | 03:26 PM
verskel's Avatar
verskel
Default Re: Hood clearance question (Monkeywrench)
Good lookin' angles, Monkeywrench ! :D
...your paint job may not be original but it's :cool: to me !
That purple just screams 70's :D
Old Mar 29, 2002 | 03:46 PM
villare's Avatar
villare
looking at BB wowbagger hood does not look like the 88 hood monkey wrench's hood it looks more like a high rise hood am i wrong?
Old Mar 29, 2002 | 04:44 PM
Monkeywrench
My hood is a "true" reproduction L-88. I think BB's hood is a molded on scoop. (Nothing wrong with that just clarifying the differences)
Old Mar 29, 2002 | 05:04 PM
BB wowbagger
My hood is not a "mold on".Its in one piece..I call it a"L88",but it might not be accurate to 100%,but it still looks good though.. :cool: :cool:
Old Mar 29, 2002 | 05:19 PM
villare's Avatar
villare
Sorry guys i did not mean to get you guys excited it, the only reason why i wanted to make sure if it was a high rise or l88 is because i have seen a hood called high rise by vanacor in the last houston vette show and it looked very close to yours(wowbagger). I just have not seen it installed in a vette, and i am interested in getting one because of clearance under the hood, but i dont want the hood so far out from the stock look so wowbagger if you have any other pictures from the front or side would you post them for us to see. I think it looks great on your vette.
thanks guys
ray
Old Mar 29, 2002 | 05:48 PM
BB wowbagger
Let me get back to you regarding the "front photos".I have som but they are really bad because i shoot it with a poor digitalcamera.. :D Did the "real"L88 hood habe scoops on the front were the bulge beginns? :cheers:
Old Mar 29, 2002 | 06:15 PM
verskel's Avatar
verskel
Check out this hood scoop ! :D :cool:
http://www.corvettes-musclecars.com/corvette/69Baldwin/
Old Mar 29, 2002 | 06:36 PM
villare's Avatar
villare
Default Re: Hood clearance question (verskel)
monkeywrench's picture of his hood is a l88 hood it has a sharp line in front of the rise instead of a smooth line like the normal high rise and it has a induction openning in the front.
To Hood clearance question
