Best Points-to-electronic ignition conversion kit
Old Sep 7, 2010 | 02:36 PM
capth4u's Avatar
capth4u
Default Best Points-to-electronic ignition conversion kit
Hello ... what is the best points-to-electronic ignition conversion kit for the price? I want to convert my 1968 327 Automatic w/Tach & advance vac.....Also.. is that the correct name for it? I did a google search and I did not find many. Thank you all
Old Sep 7, 2010 | 02:50 PM
billla's Avatar
billla
St. Jude Donor '14
I can't speak for "best", but I've installed the Pertronix kit a number of times and I've been running one for about 6 years. The engine makes about 425 flywheel HP and I've never had any issues.
Pertronix Performance Products
http://www.pertronix.com/prod/ig/ignitor3/default.aspx
Old Sep 7, 2010 | 03:42 PM
oldsarge's Avatar
oldsarge
Pertronics has woked for me for years in both my 64 & 73. Nice thing about them is they fit right in the stock distributor with no other external equip. needed. Looks factory correct when done, with exception of the wires to coil, etc. but can't really see them with the shielding, and they provide a much better performance than stock points and condensers, IMHO.
Old Sep 7, 2010 | 03:43 PM
71406's Avatar
71406
Running pertronix for 8 years without a problem.
Old Sep 7, 2010 | 05:10 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I run Pertronix (part number 1181?) in five old Chevy's. No problems ever. I also run their FlameThrower coil and a full 12v.
Provides plenty of reliable spark and all looks perfectly stock.
Old Sep 7, 2010 | 09:20 PM
Solid LT1's Avatar
Solid LT1
I'm in the Pertronix camp been there since 1982 or so when it was known as the Perlux Ignitor (Perlux was a truck lighting company.)
We carried them in the NAPA store that I worked my way through college at, spending more time worried about the tasks that needed to be finished to compete in my MOPARs at the weekend street races rather than my school grades
Old Nov 6, 2010 | 11:29 PM
newbie2vette's Avatar
newbie2vette
My apologies for reviving an old post. I was looking for some advice on which unit to replace the points on my 1972 LT1 and found this post, I thought I would ask my question in this post instead of just starting a new post on the same topic.
My question is:
The previous owner replaced the stock dist with a malory dual point dist. Will this P/N work on this dual point dist?
Old Nov 7, 2010 | 11:57 PM
Solid LT1's Avatar
Solid LT1
Are you plnning on keeping the Mallory dist? There is a Ignitor kit for a Mallory but, I would install a stock Delco cast iron TI distributor in a LT-1 Vette myself.
Old Nov 8, 2010 | 02:05 PM
newbie2vette
I did plan on re-installing the stock dist, since it was rebuilt prior to me buying the car.
Old Nov 8, 2010 | 03:53 PM
Tom@Zip's Avatar
Tom@Zip
Platinum Supporting Vendor
Corvette Ignition Upgrades
We offer many upgrades for distributors.
Give me a call with any questions
1-800-962-9632 ext 240
Tom
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles | Corvette Parts Blog
Old Nov 8, 2010 | 09:21 PM
gdh's Avatar
gdh
Tom,
What's the main difference btn PII and PIII - I've been running a PII since they first came out.
Old Nov 9, 2010 | 08:25 AM
Tom@Zip's Avatar
Tom@Zip
The Ignitor I is just a Hall-effect trigger for the coil, the Ignitor II adds microproccessor control for a more stable and effective trigger signal at higher RPM, and the Ignitor III incorporates an even more advanced control unit to increase coil output, along with a built in rev-limiter.
They all function well, fit under the cap, and are a nice upgrade over points.
Old Nov 10, 2010 | 08:52 AM
jackson's Avatar
jackson
Best for the $:
Crane XR-i 750-1710
Best Regardless of $:
Lectric Limited Breakerless SE 38131
To Best Points-to-electronic ignition conversion kit
