Holley Carb. trouble....eeek !
Old Mar 29, 2002 | 03:38 PM
verskel's Avatar
verskel
Default Holley Carb. trouble....eeek !
Ok, for the past year everything's been good - Holley 750 silver series w/vacuum secondaries.....
....then the front float bowl stuck on me. Anyone have tips on how to adjust the float level properly without squirting gas all over the place ?!? :confused:
It's running fine now but it probably has 'room' for improvement... I had to tear into it twice last night and set the float with the front half off the carb. :eek: ....oh by-the-way, the 'other' bowl had a 'stripped' float shaft and that was off the 'newer' carb - gee, thanx Holley :(
Old Mar 29, 2002 | 04:25 PM
still-learning's Avatar
still-learning
Default Re: Holley Carb. trouble....eeek ! (verskel)
I have a holley 650DP that when we got it new, had metal shavings in it. :( That thing stuck the needle three times on me. Once it was pulled, gutted, totally cleaned, and rebuilt (by my mechanic) we have not had any problems since.
Could be a possibility... Good luck.
Tim M.
Old Mar 29, 2002 | 04:40 PM
verskel's Avatar
verskel
Thanks, Tim ! :)
... why is your car on a flatbed ?
Old Mar 29, 2002 | 05:30 PM
woodenichols's Avatar
woodenichols
Verskel,
I thought that was just part of owning a Holley. Make sure you take a screw driver with you everywhere you go! :D
Steve
Old Mar 29, 2002 | 06:07 PM
verskel's Avatar
verskel
Default Re: Holley Carb. trouble....eeek ! (woodenichols)
Yeah & a 5/8" wrench, too - very funny, Steve ! :jester
Hey, btw - are you going to the 'car meet' tonight at Tippin's ? :chevy
Old Mar 29, 2002 | 06:44 PM
woodenichols
I haven't seen anything over in Southwest section yet. I think it is going to rain. I do not have anything else going on so could go if there is going to be some activity. :)
Steve
Old Mar 29, 2002 | 06:54 PM
verskel's Avatar
verskel
Here's the forecast....
Tonight
Mostly cloudy with a chance of showers and thunderstorms. Lows in the mid 50s. Northwest winds 5 to 15 mph becoming east late this evening. Chance of rain 30 percent.
...call me later if you're goin' :chevy
Old Mar 29, 2002 | 07:00 PM
woodenichols
We are definetly going. Just talked to Rick and he is going too. Jenn has posted in Southwest so there should be others there. We will see you there. :cheers:
:seeya Steve
Old Mar 29, 2002 | 07:02 PM
verskel's Avatar
verskel
B-b-bb-r-r-r-u-u-u-um-m-m-m !
ok, I'm there !!! :D :cool: :chevy
To Holley Carb. trouble....eeek !
