Bubble Tail Lamps
Old Mar 29, 2002 | 03:41 PM
Aaron76's Avatar
Aaron76
Default Bubble Tail Lamps
There are two sets you can buy one just the lenses (sugested 73 and older)and the other with lenses and wiring to make it a dual tail light system but if you were to do the wiring yourself then I wonder would the lenses only package fit and be good enough for my 76. The reason I ask is the price diff is about 100 bucks.
Thank you
Old Mar 29, 2002 | 05:39 PM
454Big's Avatar
454Big
Default Re: Bubble Tail Lamps (Aaron76)
Aaron, with a 76 you will need the expensive kit.
This one supplies also the rear housings for the lenses.
68 - 73 had three bolt holes in the lenses - positioned 12 / 4 / 8 o´clock.
74 - 82 had two bolt holes in the lenses - all positioned 3 / 9 o´clock.
Sorry Dude, you need to go the expensive way.......
Old Mar 29, 2002 | 05:44 PM
Aaron76's Avatar
Aaron76
Default Re: Bubble Tail Lamps (454Big)
Thanks for the info :cheers: .
I wasn't sure and I could not get a straight anser form the one supplier that I contacted. :mad I'm glad I know now
To Bubble Tail Lamps
