points question
Old Sep 8, 2010 | 08:56 PM
johnnygascon's Avatar
johnnygascon
Default points question
My car hasn`t run in 16 years, I`ve lubed and cleaned everything and spun the engine over. I replace the points and condenser no fire at the plugs or points. Should I see spark at the points when the cap is off? My meter shows 11 volts on both sides of the coil, what else should I check? I also changed the capacitor on the coil.
Old Sep 8, 2010 | 09:16 PM
wombvette's Avatar
wombvette
Did you make sure the points were making contact and opening when the engine is turned?
Old Sep 8, 2010 | 09:33 PM
johnnygascon
Got fire!! Points were just to out of adjustment. Thanks! Bout to fire it up!! Cant wait!
To points question
