Window Stuck down
Old Sep 9, 2010 | 10:43 AM
Nukevette81's Avatar
Nukevette81
Default Window Stuck down
How do you mechanically raise the window without taking everything out? I believe it is a wire issue not the motor. looking at replacing the radiator any suggestions on the best for cooling a 81? 3 or 4 pass alum, or stock
Old Sep 9, 2010 | 10:53 AM
ED79's Avatar
ED79
Well somethings possibly wrong inside and will have to be removed anyway to fix it so, now may be the time, good luck. Dewitts for radiator. Ed
Old Sep 9, 2010 | 11:04 AM
MrJlr's Avatar
MrJlr
DeWitts all the way.
You're going to have to pull the interior door panel off and have a look in there for the window problem...
Old Sep 9, 2010 | 02:23 PM
Rikoshay's Avatar
Rikoshay
On mine the pass side window went all the way down and would not come up. It had always been extremely slow, but then it finally got stuck.
I removed the door panel and could lift it up while pushing the button but there was a lot of resistence. I squirted motor oil along the channels that the rollers go up and down in, and lubricated everything else that moved or pivots.
After letting it soak I was able to get the window to go fully up/down. Re-lubed and it now moves really fast up/down. At some point I'll have to pull the drivers door panel and do the same.
Old Sep 9, 2010 | 02:35 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
My 75 if you take it all the way down it will stick on the way up I grab the glass and shift it form front to back and all the sudden it tracks up and the window closes .good luck
Old Sep 10, 2010 | 11:28 PM
thomaskh's Avatar
thomaskh
I had same problem on C3 power window.
Door panel removal is pretty straight forward. Once removed and your in view of window motor listen to see if it is getting power or use test light. If not getting any power at motor check window switch with test meter. You can jump over from a hot wire to test motor, it may be a switch problem. If needing to replace switch this is good, as it is much less than a new motor.
If motor is running at all but window stuck down see if you can give it (window) a little careful boost. If that works lube should make a difference to tracks/mechanism.
If motor has gone bad then you will need to drill rivets out to remove motor and replace.
Dadgum things happen even to newer vets, C6 window is now making noise when going down. Sounds like finger nails on a chalk board.
Good luck.
Old Sep 11, 2010 | 12:22 PM
Rikoshay's Avatar
Rikoshay
The grease in my roller channels had turned into tar. Getting the sticky crud out and re-greasing was the cure for mine.
Old Sep 11, 2010 | 07:45 PM
Nukevette81
Thanks looks like a switch, and motor get power in one direction but not the other motor trys to move in down direction havent had any luck in the up. everything is out of the door not and I am working on re assembly. any suggestions?
Old Sep 14, 2010 | 04:25 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Move the wires on the swithes around. if it works its the switch.
Old Sep 14, 2010 | 07:52 PM
Roadking's Avatar
Roadking
Open the door fully hold the switch in the direction it does not operate and gently wiggle the rubber between door and body at the jamb.
Old Sep 15, 2010 | 10:33 PM
Nukevette81
Wound up replacing switch and completely replaced all of the rollers very loose and i fugure since it was going to come apart I did not want to do it twice. Thanks to all
Old Sep 16, 2010 | 09:58 AM
thomaskh's Avatar
thomaskh
Sounds great, switch was the problem, and no new motor needed.
I have to work on my drivers side window now.
To Window Stuck down
