72 headlight switch handle removal
Old Sep 10, 2010 | 05:14 PM
jnb5101's Avatar
jnb5101
Default 72 headlight switch handle removal
i've pushed the little spring loaded button, but the handle won't release.
any other suggestions?
Old Sep 10, 2010 | 05:30 PM
calif phil's Avatar
calif phil
Pull it out to the headlights "on" posistion and then depress the release tab and it will come right out.
Old Sep 10, 2010 | 06:50 PM
jnb5101's Avatar
jnb5101
phil, you're a genius! i don't care what everyone else says!!!!
thanks
Old Sep 11, 2010 | 11:09 AM
calif phil's Avatar
calif phil
Glad I could help.
Old Sep 11, 2010 | 08:57 PM
vettes4evr's Avatar
vettes4evr
Since we're on the headlamp switch, I have a question also. How does the plastic bezel that says "Headlamps" get secured? Mine spins around and I have to push it back in place. Is this threaded, with a nut on the inside of the dash, or does it secure to the headlamp switch? Instead of fighting to get back there, I'd prefer to use double sided tape to hold it in place!
Old Sep 11, 2010 | 09:02 PM
72LS1Vette's Avatar
72LS1Vette
There is a little plastic pin that engages with the switch to line up the bezel. Sounds like maybe the pin has broken off your bezel. There is a nut that threads onto the switch to hold the bezel securely. The switch would fall out if the nut wasn't there so maybe you just need to remove the nut, put the bezel on, and thread the nut on.
Rick B.
Old Sep 11, 2010 | 09:52 PM
vettes4evr's Avatar
vettes4evr
Thanks Rick. Now where can I find a squirrel talented enough to send up in there to do that for me? Oh well, I've been looking for a reason to pull that dash pad anyway. -Ken
To 72 headlight switch handle removal
