BB Headers and rear A/C Compressor Bracket
Old Sep 12, 2010 | 10:17 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Default BB Headers and rear A/C Compressor Bracket
To those of you who are running headers and A/C on your BB Vette, what did you do for a rear compressor bracket? (The original A6 compressor).
Spacers?
For my SB cars with headers I've run a bracket similar to this:
http://www.summitracing.com/parts/HED-20110/
Is there a BB equivalent? I've searched but no luck.
Any other ideas?
Thanks!
Old Sep 12, 2010 | 10:40 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I would try the original studs with some washers or a spacer.
Old Sep 13, 2010 | 12:00 AM
Rebelrob's Avatar
Rebelrob
There are two brackets for the BB AC compressor. One mounts on the front of the head and the other that mounts on the side of the head using the header/exh manifold bolts.
I have both of them, and might want to sell them since I may not be able to use them.
Old Sep 13, 2010 | 12:29 AM
73, Dark Blue 454
I have both brackets and will use the front bracket. Headers (vs. stock exhaust maniolds) will reposition the rear compressor bracket closer to the engine by about 5/8" to 3/4". This will cause alignment problems.
I could fab spacers I suppose. Or I was hoping the aftermarket had a bracket for use with headers. They do for SB but apparently not for BB.
Or, if others solved this problem another way, please enlighten me.
Thanks!
Old Sep 13, 2010 | 12:32 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I solved that problem by throwing that ugly A6 away and put a nice Sanden 508 compressor instead.
Old Sep 13, 2010 | 09:30 AM
crf311's Avatar
crf311
How about a thead with some pictures and a write up about this swap?
Old Sep 13, 2010 | 11:37 AM
Rebelrob's Avatar
Rebelrob
That A6 is a grizzly bear. Im not sure how much it weighs, but its heavvvvy...
I feel your pain on the modding of brackets, spacers etc. I am going thru the same issues. I am trying to bolt a SB R4 compressor bracket to a BB. It is not fun. Only had to have it welded and cut once thus far.
To BB Headers and rear A/C Compressor Bracket
