msd 6al wiring question
Old Sep 14, 2010 | 08:51 PM
mj9311's Avatar
mj9311
Default msd 6al wiring question
so im wiring up the 6al on my 76 and i have to hook up the red wire to the old coil+ which is also the ign key wire. i beleive ir is the pink wire but there is also a smaller brown wire that has a metal resistor of some sort inline and i cant find anything about it on the wire diagrams. im pretty sure i have it right with the pink wire but what then is this brown wire???
Old Sep 14, 2010 | 08:58 PM
SteveG75's Avatar
SteveG75
Brown wire is the tach input.
Old Sep 14, 2010 | 09:03 PM
mj9311's Avatar
mj9311
and where does that get wired up to?? im going to be using the 6al with the probillet distributor
Old Sep 14, 2010 | 09:57 PM
SteveG75's Avatar
SteveG75
The brown wire from the HEI is connected to a in-line filter which is attached to another brown wire in the wiring harness. Disconnect the filter and connect the brown wire from the harness to the tach output of the 6AL box.
It is on pages 2 and 7 of the instructions:
http://www.msdignition.com/uploadedF...uctions(1).pdf
Old Sep 14, 2010 | 11:09 PM
mj9311's Avatar
mj9311
thank you i didn't realize it was just a recessed male end of a plug
Old Sep 15, 2010 | 06:44 AM
CFD E59's Avatar
CFD E59
Your really going to like that 6AL
To msd 6al wiring question
