Speedometer issue
Old Sep 15, 2010 | 07:24 AM
cobia02's Avatar
cobia02
Cruising
Default Speedometer issue
Can anyone tell me where to get the little plastic/teflon (?) gear assy that goes into the trans for the speedometer cable? It's for a 1973 350 eng with a 4 speed. I'm not having much luck with this one. Thanks.
Old Sep 15, 2010 | 08:10 AM
BKbroiler's Avatar
BKbroiler
I've gotten them from Zip. They might still be available at Chevy dealers.
Old Sep 15, 2010 | 08:12 AM
bashcraft's Avatar
bashcraft
GM dealer.
Old Sep 15, 2010 | 09:34 AM
Tom@Zip's Avatar
Tom@Zip
Platinum Supporting Vendor
We have several of these gears in stock and ready to ship. A good rule of thumb is a one tooth difference equals around 1 1/2 mph.
Speedometer gears
Feel free to give me a call if you have any questions.
Tom 1-800-962-9632 ext 240
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles | Corvette Parts Blog
Old Sep 15, 2010 | 10:34 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
73 4 speed cars could have used many different gears based on the rear end that is in the car. The chart at this link contains the GM original part numbers and you should be able to find one at any dealer. Buick, Pont, Cady or Chevy. But you should remove the old gear first and count the teeth! This is the easiest way to make sure you are getting what you have.
http://willcoxcorvette.com/repairand...lp.php?hID=135
Assuming you have the original drive gear in the car your car could use a 18, 19 20 or 22 tooth gear.
Not trying to argue with what Tom posted above, but if you are trying to make an adjustment in the speedometer, 1 tooth is equal to about 5 mils per hour.
Willcox
To Speedometer issue
