Budget 383 rotating assembly ?
Old Sep 15, 2010 | 08:31 PM
sting66cp's Avatar
sting66cp
Default Budget 383 rotating assembly ?
What do you guys think of a 383 rotating assembly like this for a budget build?
Has anyone used a kit like this, good or bad experiences?
http://cgi.ebay.com/ebaymotors/Eagle...Q5fCarQ5fParts
Old Sep 15, 2010 | 09:09 PM
BLOCKMAN's Avatar
BLOCKMAN
Becare of the eagle sir rods as I have seen alot of issues with them if you do a search it should have some good info to look over.
Befoe you do anything with the crank try a harmonic blancer on as we had a cusotmer bring in 2 for balancing and both you could push the balancer on by hand and he called Eagle and they said it was fine HMMMMMMMMM
He sent them back and went to a scat crank the snouts measured fine.
Becareful
Old Sep 15, 2010 | 09:50 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I really don't care for Eagle either I returned one their more expensive forged stroker cranks because it wasn't straight enough for me, you can get a scat9000 crank and use their forged rods for about the money
Old Sep 15, 2010 | 09:52 PM
L88Plus's Avatar
L88Plus
Scat stuff tends to be a lot closer to spec, as BlockMan said.
I'd buy the parts individually, then have them balanced locally AFTER trial fitting and grinding where needed. Scat makes a good cast crank, their entry level capscrew rods are solid pieces, I'd probably use SpeedPro pistons and Clevite bearings along with moly rings. There's a lot bigger selection of pistons for this combo with 5.7" rods than either stock or 6.0, keep that in mind.
While you're at it, check at your local machine shops and see if you can find a good 4-bolt 1-piece rear main seal block that's drilled for a mechanical fuel pump. OEM roller lifters are inexpensive as are cams for 'em, plus you'll get the 1-piece rear main for less headaches. Also, if your engine is original, you'll get to store it for future use, if you ever decide to take it completely back to stock.
Old Sep 16, 2010 | 08:15 AM
jackson's Avatar
jackson
also ...best to state up front what year-model you're working with & how you'll use it.
also ... if you use small combustion chamber heads (like most '69 sbc came with) you probably will not want a flattop 383 ... the compression will likely be too high for mild street ... see dish/reverse dome piston
before you buy anything ... identify what heads you'll use & learn to use a reliable static compression ratio calculator such as this one from Federal-Mogul aka sealed power/speedpro
http://www.fme-cat.com/Calculator4.aspx
Old Sep 16, 2010 | 02:19 PM
Tumarr's Avatar
Tumarr
Well I have used eagle components for several engines I have built including a 383 stroker, 496 stroker, 408, 540 bbc. All were very powerful engines that never had a rotating component failure after several dragstrip passes and street miles. The 383 engine could do low 11's in the quarter mile on motor and was sprayed with a 150hp shot of nitrous to go low 10's in a 3400lbs camaro. I used pretty much the same kit you posted. This was my little brothers car and he must of put over 20,000 miles on the engine and over 100 1/4 passes on it before we sold it in perfect working condition so that we can upgrade the engines power. the vette in my sig had an all eagle rotating assembly 496 that was doing 8.30's on 400 shot of nitrous. 9.90's on motor only. never hurt the short block on it.
To Budget 383 rotating assembly ?
